peugeot 106 crankcase leaking oil from vent
03.04.2022 22:08 # 1
Faruk4787
Hello friends, when my 106 xs vehicle gives gas from the crankcase ventilation hose, it throws oil like crazy, what is the problem?
06.04.2022 22:23 # 2
talip206
There is the upper rocker cover, that is, the cover with the Peugeot logo on the top when you look at the engine. Two screws hold it. When you open it, there is sheet metal underneath that prevents oil splashing. Maybe previous owners didn't wear it. There seems to be no other possibility.
09.04.2022 02:37 # 3
Faruk4787
Thank you, the gasket of the rocker cover is worn out, I will change it. When I give gas, it throws oil from the gasket, I will change that part when I open it, I wonder what the name of the part is, thanks for your comment.
09.04.2022 20:31 # 4
talip206
I don't know what his name is. If it's leaking that much oil, it's probably because that part has never been installed. I'm leaving the link below, part number 11
