Peugeot 106, 306, 406, 605 ABS ECU Error Codes.
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:53 # 1
rifatseker
Alıntıdır.
PEUGEOT 106 1996-97 Error codes.
Fault code Fault location
015Z The system relay.
018Z Rotors on the wheel speed sensor.
024Z Rear left wheel speed sensor.
025Z Front right wheel speed sensor.
031Z Rear right wheel speed sensor.
032Z Front left wheel speed sensor.
033Z The signal of the wheel speed sensors.
053Z The pump motor
055Z ECU
057Z The battery voltage is low.
058Z The battery voltage is high.
066Z In the ABS operation
067Z In the ABS operation.
068Z In the ABS operation.
069Z In the ABS operation.
087Z Fault with diagnosis output.
091Z The warning lamp.
095Z With the hydraulic connections.
096Z The connections to the wheel speed sensors are transposed.
097Z Is an external signal interference.
099Z No fault is found.
PEUGEOT 306 (after `` after 97), 406 (95-96), 605 (96-97) Error codes
016Z The BPP (Brake pedal position) switch.
018Z Rotors of the wheel speed sensors.
042Z The valves of the hydraulic modulator solenoid.
044Z The valves of the hydraulic modulator solenoid.
051Z The valves of the hydraulic modulator solenoid.
052Z The valves of the hydraulic modulator solenoid.
053Z The pump motor.
055Z The ECU.
057Z The battery voltage.
096Z The connections of the wheel speed sensors are transposed.
