Peugeot 106 3.5 cm spring
08.05.2020 15:18 # 1
aclern
I ordered a 3.5 cm spring for my 106 vehicle, but it says exactly on the package "Pro-Kit Peugeot 206 (2A / C)" We ordered these springs as 106 but it came like this. Is the 206 springs suitable for 106? Vehicle quiksilver
08.05.2020 15:18 # 2
aclern
The incoming broadcast model is E7025-120. But the spring for 106 looks like E7016-120. The seller said that these springs are suitable for 106.
08.05.2020 15:18 # 3
Emre Ekrem
106-206-205 are compatible with each other without any problems, 306 also makes sounds. You can use it smoothly.
08.05.2020 15:18 # 4
aclern
Of course, you should not be an experienced member. Thanks.
08.05.2020 15:18 # 5
ilicik
3.5 mm or 5 mm me will lower the vehicle more?
08.05.2020 15:18 # 6
Compatible ..
@ilicik drops 5cm more. As the name suggests, 5cm already lowers an average of 5cm, 3.5cm an average of 3.5cm
08.05.2020 15:18 # 7
Lowers 5 Cm Further
Lowers 3.5 Cm Less Moderate
The vehicle in the picture is 3.5 cm spring mounted and you can get off the road. Göz Kırpma
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=14137&title=06sp873-35cm-yay-taklm-hal
the albaydemirc 2011-04-21 15:51:38
08.05.2020 15:18 # 8
Burak07
there is no problem :) bnm on my vehicle has 206 spirals :) just watch out for your mind in a pit the front team is harvested :))
08.05.2020 15:18 # 9
Emre Ekrem
Depending on the weight of the vehicle to be applied, if your vehicle is 106 QS and 3.5 mm of the springs 206 you will use, the engine weight of your vehicle is important. The springs you will take will reduce 206 to 3.5mm, but if your vehicle is lighter or heavier, it will vary considerably accordingly. As an example, since I did not have 5mm springs made on my 306 gti vehicle, I used 3.5mm springs attached to 106 and it dropped about 6mm.
In short, it is useful to learn the weight difference between your own vehicle and 206.
undertaker 2011-04-21 16:25:07
08.05.2020 15:18 # 10
aclern
In fact, my vehicle now has a 5 cm spring and they have changed the spring to drop 6 cm, wedge etc. with. The vehicle is in many places right now. But I don't want to get up too long. I wonder if I made a mistake by taking 3.5 cm. Though it can be changed later, but we'll see.
