Peugeot 1.4hdi engine malfunction lamp and sudden stop
08.05.2020 18:48 # 1
Peugeot1907
Friends I'm a Peugeot 1.4 hdi user problem of my car
When my vehicle slows down while driving, the engine malfunction lamp turns on and my car stops and when I turn the ignition off, the car restarts, the malfunction lamp remains and after a while the lamp goes off and this malfunction occurs in 1 to 2 days.
I have deleted this engine malfunction in the service before and used it for 1 week. Does anyone know the solution again?
Peugeot1907 2014-09-19 22:21:30
08.05.2020 18:48 # 2
Peugeot1907
This fault that happened to anyone who knows if there is 1.5 months, the vehicle could not be found in this case
08.05.2020 18:48 # 3
suppor
I have done 10 thousand km more and the pain lamp did not burn on the road. Show me a master, I think the doctors are diagnosing without examining them.
08.05.2020 18:48 # 4
pusutr
Is the radiator water level normal? Have oil filter changes been made? Is gearbox oil vs sufficient and good quality? are the filters original? What is the temperature when the engine fails? Are the gaskets healthy?
First of all, you should look at your problem after such maintenance is done with original parts.
08.05.2020 18:48 # 5
Peugeot1907
I had the car inspected and sent the fault from the computer, they said there was no problem because the fault did not appear, but it is still the same ..
gasket etc was changed due to overheating 2 months ago
There is a situation like this, there is a little diesel leak after the gasket replacement.
08.05.2020 18:48 # 6
I don't understand why, but if the engine sign is on, the oxygen sensor is faulty or it may be inside you push the car too hard. I pushed mine for a while 1.4 hdi rpm did not come down from 5000 engine light lit I stopped forcing :)
08.05.2020 18:48 # 7
Peugeot1907
master, I am confronted with a strange situation, I can say that the car has cooled me from peugeot.
08.05.2020 18:48 # 8
Peugeot1907
Do you have any expert advice for the vehicle?
08.05.2020 18:48 # 9
KILIC
[QUOTE = Peugeot1907] master, I am confronted with a strange situation.
The whistling sound is normal at high speeds, while the car is forced while the ramp is going out, a whistling sound sounds.
The flashing of the malfunction lamp is caused by many reasons. It is very difficult to say something from here. It is necessary to go to a competent master and look at the error codes.
08.05.2020 18:48 # 10
The sound of the turbo comes from the turbo.
08.05.2020 18:48 # 11
Peugeot1907
Does the whistling sound come because the exhaust manifold is loose?
The malfunction lamp is running out of fuel, but we couldn't solve the reason.
08.05.2020 18:48 # 12
pusutr
There may be a problem with fuel popping or due to contaminated fuel due to clogging in the tank / pump / hoses / diesel filter etc.
