PEUGEOT 1.4 VTI The car has gone crazy! |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 08.05.2020 20:38 | # 1 |
a thousand kilometers ago periodic maintenance was done there was no problem put the oil 5-30 full synthetic was different before, but there was no problem in the sound again started Even at 100 in the 5th gear, the car is trembling, we pressed the pad and said to the master very well. I don't understand, I don't understand This sound comes from the car |
| 08.05.2020 20:38 | # 2 |
sonerkyl |
brother look at engine ears and axle heads. There is no problem in your work.
| 08.05.2020 20:38 | # 3 |
No, I go to school every day, but the car started to shake in the bidet.
| 08.05.2020 20:38 | # 4 |
the sound comes from the engine
| 08.05.2020 20:38 | # 5 |
sonerkyl |
I can't listen to the sound, unfortunately my brother is closed on youtube :) I listen when I go home in the evening.
| 08.05.2020 20:38 | # 6 |
okay brother, the answer will surely be atda, i will buy the car ford taunus 2.0 gls: DD
| 08.05.2020 20:38 | # 7 |
The situation may have emerged as a coincidence that is unrelated to the oil, the oils you mentioned generally make the vehicles run quieter. Nevertheless, it is necessary to have his master examined, not to be immediately attached to the oil. |
| 08.05.2020 20:38 | # 8 |
You didn't write ????
| 08.05.2020 20:38 | # 9 |
sonerkyl |
my brother, the sound is like something is striking, but it is better to listen next to him. This market will meet 308 in anteras, if you can come early, let's have a look there, brother. mobile phone: 0505 789 36 33
| 08.05.2020 20:38 | # 10 |
[QUOTE = sonerkyl] my brother, the sound is like something is striking, but it is better to listen next to him. This market will meet 308 in anteras, if you can come early, let's have a look there, brother. mobile phone: 0505 789 36 33 [/ QUOTE] As far as you can see, what's wrong with the brother?
| 08.05.2020 20:38 | # 11 |
sonerkyl |
Well my brother is not understood in the video, frankly I should not lie now. it would be better if you were available and come.
| 08.05.2020 20:38 | # 12 |
ggitaristt |
It seems to me that it is like engine chock .. I hit the bottom of the car, the chock was rotten inside was empty .. The engine sound was like this. The machine became like zero after the 20-pound wedge .. Edit: I have reset all of the top chock bottom chock or something .. The gas goes like a gas to soft pressure .. |
