peugeo 307 glass self-opening yard
08.05.2020 18:51 # 1
raconcu
Hello friends, first of all, I wish everyone good forums. My car is 2006 model 307 1.6 hdi. I have been having a problem with the driver glass for 3 days. The window does not open on its own, it does not close, or when I try to open it, it does not close completely.
08.05.2020 18:51 # 2
pekmez006
teacher, remove the handle carefully, have the socket underneath, carefully remove and clean
08.05.2020 18:51 # 3
raconcu
Solve this simple, hojam? I will try as soon thank you ins. very annoying event that gets better
08.05.2020 18:51 # 4
pekmez006
yes, if it doesn't fix, remove it, there is a card inside the arm, clean that card carefully, oxidizing it usually happened to me because there is no need to bother
08.05.2020 18:51 # 5
raconcu
If I apply oil-free contact spray to the sockets, it will be cleaned better? And should I clean the card with thinner?
08.05.2020 18:51 # 6
pekmez006
Look at the card, clean its oxidized parts with a slightly damp cloth. Look at the sockets. If there is oxidation, wipe it carefully. Do not soak the electronic material too much.
08.05.2020 18:51 # 7
raconcu
teacher, I removed the handle today, there was no problem in the female and male sockets. I sprayed oil-free contact spray on the female socket. I distributed the arm completely and cleaned the card with thinner. Then I assembled again and assembled it. The problem disappeared.
08.05.2020 18:51 # 8
pekmez006
I am glad :)
