Petrol needle problem in lpg
08.05.2020 15:26 # 1
anil307
friends, first of all hello everyone, i just joined you, i bought 307 new vehicles. According to my research, if the vehicle is on the tube, it drops the needle as if it is burning gasoline, and it is based on the rotation of the wheel. I used a lpg car before. I know how the transition sound is) My car consumes both gas and gas. I was not convinced that the car switched to lpg. They call it the module for the gasoline needle, I do not want to have it tested, they say test mode. How does the needle renew itself? I would be very happy if you could help, by the way, don't be afraid.
the albaydemirc 2011-09-07 00:15:49
08.05.2020 15:26 # 2
anil307
First of all thank you for your help, it is not my only problem.
08.05.2020 15:26 # 3
maestro
open the hood, start the car and go to the hood and listen to the sound of the engine. I think it will make a change of sound. If you do not notice it, you will see that the gasoline needle is well placed.
08.05.2020 15:26 # 4
My beautiful brother, you have to introduce yourself first. Also, it would be nice if you see the necessary information on your profile. You can write your vehicle information in signature
08.05.2020 15:26 # 5
anil307
I entered a few more information, but I could not find a place to put my car photo .. I am a student in Antalya, I am an Ankara student, I am 20 years old unv student 14 days evel 307 xsi hatchback 3 doors, I bought a white vehicle, I stated the problems I wrote in the tube.
08.05.2020 15:26 # 6
anil307
I slept under the exhaust, I opened it in the hood and listened, it is not clear. the problem may be in what is called a cutter what does it cost
08.05.2020 15:26 # 7
ose
then whatever brand you are going to show it to the bottler. The piece you said should be cheap, a little thing.
08.05.2020 15:26 # 8
This LPG can be understood from the km you did? You are right if you are doing more than the km you should normally do. If there is no ending where it should be finished, the needle is wrong.
08.05.2020 15:26 # 9
anil I bought the car 14 days ago, why do you sell it under another topic?
08.05.2020 15:26 # 10
[QUOTE = anil307] I lay under the exhaust, I opened it in the hood and listened, it is not understood. the problem may be in what is called a cutter what does it cost [/ QUOTE]
First of all, let's look at what brand of lpg system in your vehicle ???
Try capturing the lpg valve while the vehicle is on the gas in the gauge. While working in the same way, pull out one of the gas injectors. Meanwhile, the motor should start shaking. Because the engine will run 3 cylinders ... it should be fixed again after plugging in.
08.05.2020 15:26 # 11
metin
[QUOTE = anil307] first of all thanks for your help, thank you alone, it is not my only problem [/ QUOTE]
First of all, let me state that the link shared by your friend is completely your problem.
First of all, when your vehicle goes to LPG, it does not consume petrol, but since the petrol pump continues to operate, the trip computer etc. all work.
When the needle falls according to the tire not rotating, the story will not fall if it runs until the evening where the vehicle is.
The truth is that;
The buoys of french cars such as renault, peugeot and citroen measure the current level once when fueled and inform the brain (BSI). The brain then calculates its fuel according to the speed you go to the way you press the gas and sends a signal to the needle and lowers it.
The needle continues to fall while going in LPG and the float does not notice the change and does not transmit it to the brain unless you get at least 7 liters of fuel. If you say 7 liters x 4.30 TL gasoline price with today's prices, the level will not change if you do not buy at least 31 TL fuel. It continues to fall from where it left off.
There are several solutions to this.
1. It is the module that plugs into the gas tank which is very common. When the module is inserted, the needle continues to button again, and this module resets the float every time the ignition is turned on and transmits the current level to the brain in the float, thereby removing the needle.
2- Our kaan__ nickname makes something like a short circuit to the cables that go to the warehouse shared by the artist, and brings the needle back to the current level.
3- If you keep the level of petrol in the vehicle's tank above the half-tank, the needle that falls on the road will reach its current level when the vehicle is restarted.
As a result, whatever you do, the needle continues to drop. These methods only serve to restore the falling needle. so you should use it like this.
08.05.2020 15:26 # 12
anil307
atikerr brand lpg m last resort and I do not know where you are looking to make me look at it. Thank you for your interest = /
08.05.2020 15:26 # 13
anil307
=) dear wants to change the car i have hobby if you have so much money
08.05.2020 15:26 # 14
anil307
Thanks for your help, this LPG job is bothering me
08.05.2020 15:26 # 15
[QUOTE = anil307]
thank you i'm happy with my car iii sales to you
08.05.2020 15:26 # 16
hunterakon
Buy 25 TL gasoline, I get 25 lira, depending on the situation in 1.5 weeks, it is getting old back, whatever I got in the warehouse is whatever I bought it means that the car burns 1.5 lira gas in 2 weeks: D otherwise, I do not think of any of these modules. Do it this way, the vehicle consumes 25 pounds of gas in 2 weeks: D simple: D
08.05.2020 15:26 # 17
metin
[QUOTE = hunterakon] Buy 25 TL gasoline. I get 25 lira depending on the situation every 1.5 weeks. The vehicle is getting back to its old state. Whatever I got in the warehouse, whatever I bought it means it will be 1.5. The vehicle burns 25 lira gas in 2 weeks. but I don't think so, I think you do it like that the vehicle consumes 25 lira gas in 2 weeks: D simple: D [/ QUOTE]
I guess your vehicle noticed the change and restored the needle when it took 4-5 liters instead of 7 liters like the 307, which is smaller than the tank of the vehicle.
08.05.2020 15:26 # 18
burakdmr
So, I have the same problem with my petrol light .. When I watch out, when the petrol light goes on after it goes off, when you turn off the ignition, the pointer finds its place after a while :)
08.05.2020 15:26 # 19
burakdmr
By the way, 120 tl lpg and 800 km idiom :))
08.05.2020 15:26 # 20
metin
[QUOTE = basistburak] by the way, 120 tl lpg and 800 km idiom now:)) [/ QUOTE]
could you share this 800 km long road data.
Page : / 2
