Petrol needle falls in LPG
08.05.2020 19:36 # 1
Msgzl3806
Vehicle 2006 1.4 feline manuel.Lpg kit lovato.50 tllik I put gasoline.When the gas tank was full, I made 350 km intercity road in lpg and gas light burned. Msgzl3806 2016-01-20 21:51:33
08.05.2020 19:36 # 2
srknkkc
gasoline needle drop is normal. a chronic problem. half more petrol from the tank, my teacher resets himself to the car when he arrives.
08.05.2020 19:36 # 3
talip206
If you search the forum there are dozens of topics related to a topic. The vehicle does not consume petrol, but the needle drops. A situation specific to French vehicles is generally. If you buy at least 7 liters of gasoline, the needle will return to its original position.
08.05.2020 19:36 # 4
Msgzl3806
Thanks
08.05.2020 19:37 # 5
mimit
There is a part called Psa module, you do not have to wonder if there is any gasoline if you put it on, the part shows the amount of fuel in the tank correctly by calibrating the vehicle's petrol gauge at every contact opening, you do not have to buy gasoline occasionally for control purposes. it needs to state it, but nobody does it.
08.05.2020 19:37 # 6
Sercan Mungan
I also think, in fact, where can we put ankara in?
08.05.2020 19:37 # 7
Gokcesel
[QUOTE = Sercan Mungan] I think too, actually, where can we get ankara installed? [/ QUOTE]
Keep no effort to keep your gas on half tank no problem :)
08.05.2020 19:37 # 8
Msgzl3806
Thank you..do you know what the module will cost me
08.05.2020 19:37 # 9
riderzist
[QUOTE = talip206] If you search the forum, there are dozens of topics. The vehicle does not consume petrol, but the needle drops. A situation specific to French vehicles is generally. If you buy at least 7 liters of gasoline, the needle will return to its original position.
Opel also so lpgli opel de petrol hand drops insignia astra
08.05.2020 19:37 # 10
riderzist
[QUOTE = Msgzl3806] Thank you..do you know what the module will cost me [/ QUOTE]
There is no need for a module, put gasoline on the luck that my teacher will give you 150 liras instead. I always travel close to the full tank, throw 1 40 50 pounds of gasoline a month, complete it, I have no problems.
If you travel a little, if your warehouse is full 4/3, it is almost the same every day.
They say that the module breaks down after a while, let the car remain original. We are already entering the brain with lpg. Let's not hit it with the module.
