Petrol lpg car start problem
08.09.2022 13:09 # 1
Pejjo
At the first start of the day, the car starts and stops when it is cold, does this 4-5 times, then starts and barely keeps its speed at idle. But in the first start of the day, when I switch to LPG under the same conditions, only one starter works. Fuel filter air filter just changed. What makes this problem, from the gas pump? I suspect the injectors. Could you help. Have you had such a glitch?
08.09.2022 15:49 # 2
talip206
It makes a gas pump, sir. It does not provide enough pressure when cold.
09.09.2022 12:08 # 3
KILIC
As far as I understand, the vehicle is LPG powered. First of all, turn off the lpg of the vehicle from the tank at the back the night before, let it run until the lpg runs out, the vehicle will stop. Try starting it the next morning. If it works hard again, you will concentrate on the fuel pump. The gasoline return valve may be faulty, the pump may not be able to send enough pressure.
15.08.2023 17:47 # 4
Pejjo
I changed the fuel pump and injectors, but it didn't work.
