PETROL INDICATOR PROBLEM
08.05.2020 13:59 # 1
mbolun
HELLO BEYLER SHOWS MY GAS OVER THE GAS INDICATOR 1 STAGE
GASOLINE SENSOR ATMIS IS CORRECTED BACK THE SEAT BUT THAT WE WOULD LIKE WE FOUND
IS THERE ANYONE TO BE A HELP WITH KNOWLEDGE OF THE VEHICLE 106 GTI
08.05.2020 13:59 # 2
Gntss
sometimes I had an increase when I put gasoline.
08.05.2020 13:59 # 3
sinan-s
The problem is from the buoy.
08.05.2020 13:59 # 4
Ismail
[QUOTE = sinan-s] The problem is from the buoy .. [/ QUOTE]
I agree with my brother Sinan
08.05.2020 13:59 # 5
aoc
In most of the 106s, the fuel gauge is problematic ... You have to look at the km, the indicator can be misleading.
08.05.2020 13:59 # 6
deniz_206
If I say to my brother, get an idea
08.05.2020 13:59 # 7
mbolun
well but I have never seen the light of gasoline lit up in the quarter tank :)))
08.05.2020 13:59 # 8
It may be on the float, or it may have been repaired before.
08.05.2020 13:59 # 9
hasimayaz
possible float (part 2) .. but if played with the instrument panel, there might be a problem.
08.05.2020 13:59 # 10
hello to everyone; (2004 206 1.4 hdi)
I had the same problem. The weather saw -12s last night but I did not drive for 2-3 days. diesel needle was a quarter of a warehouse, then I walked a bit and looked at the hand. I entered the opete to get fuel, I bought 20 liters of diesel, but the hand did not move, then I suspect I got another 10 rubles from another place, but still did not move. then the pointer began to drop slowly. Diesel light is on now, but there is still diesel in the tank;
If we pull the diesel in the tank and put it back to normal, do you think this is an electronic failure?
08.05.2020 13:59 # 11
Hello to everyone,
The problem with diesel fuel problem has been solved, the buoy has been cleaned. the car was put into the computer. the service finally said it was buoy failure said it needed to change ..
A master at the service said that peugeots would make this problem by looking, and when he did not complete the tank, he would adjust himself and return to normal. I did exactly that now everything is back to normal ...
