Pertner High Speed Low Speed Problem
08.05.2020 17:50 # 1
salemsmithh
Hello friends. 2006 model 2.0 hdi partner. I used the 2006 model 2 times before. (From those with 7,000 cycle hours). These tools are for example 2. the speed is 60-70 km at 4,000 rpm & nbsp; speeding. & nbsp; 5. gear 140 km per 3,000 cycles & nbsp; accelerates & nbsp; (5th gear 4,000 rpm 170 km) & nbsp; But there is something weird about my new partner. & Nbsp; 2. 20 km at 2,000 rpm 30 km at 3,000 rpm 5 th gear 95 km at 3,000 rpm 110 km at 3500 rpm & nbsp;. The Buddha causes it to drink officially. What would be the reason for this, I would be glad if you help :)
08.05.2020 17:50 # 2
Serkan
The pressure may be missing the pad hojam, the car gas rolls over but does not speed up
08.05.2020 17:50 # 3
Carmania
[QUOTE = Serkan] The pressure may be missing from the pad hojam, the car gas rolls over but does not speed up
so..
08.05.2020 17:50 # 4
salemsmithh
[QUOTE = Serkan] The printing may be missing the pad, teacher, the car gas is overturned but does not speed up
Hodja Bi is in the same vehicle near me. He used it, tested it and said it was abnormally serial. We went to the service, they do not miss the clutch, but since they are at 110.000 km, they should change now.
08.05.2020 17:50 # 5
SDYMZ
I think you show it to another service, the pressure is from the brake pad, 110 thousand km is not much, if the maintenance was done on time
08.05.2020 17:50 # 6
salemsmithh
do you have any guesses?
08.05.2020 17:50 # 7
salemsmithh
unfortunately the vehicle was unnoticed
08.05.2020 17:50 # 8
Serkan
Clutch does not change km, if my teacher is intact, it does not change, 30.000 have print finishers 200.000 have finishers
