Performance problem
08.05.2020 20:54 # 1
savasdemirci
Hello, 2007 Model 1.6 Hdi There was a problem that we could not solve in my vehicle at 350 thousand KM. The vehicle is experiencing poor performance at any time, and the accelerator pedal feels as if it is wasted. There is a problem that somehow affects the turbo. Turbocharger test results turns out to be normal, so I got the original zero on the turbo last year, egr was canceled, the turbo valve changed 4-5 times, almost everything about the air flow has changed, the exhaust is clean and empty. When this problem occurred I put it into the dyno test showed 60hp. It is said to be in the brain or in the fuse board. 4 - 5 different computer test inputs occasionally give P0299 errors.
One moment of the vehicle does not hold the other moment, you have a good look and crawls after a few hours.
I am waiting for the help of friends who have an idea on this matter. Thank you from now.
the savasdemirc 2018-06-02 11:13:41
08.05.2020 20:54 # 2
Selcuk55
Did you check the flow meter, when the traction dust, is there a malfunction lamp, does 3000 cycles pass
08.05.2020 20:54 # 3
savasdemirci
Hello, the flow meter has just changed, the malfunction lamp does not light up, the speed of 3000 passes at a long distance. Occasionally we receive a p0299 error from the computer. Based on this error, the turbo valve changed 3-4 times, the connections related to the turbo were checked, but no results were obtained.
08.05.2020 20:54 # 4
Selcuk55
Unfortunately, the vehicle gives a low pressure warning, the problem still looks like a solenoid. The turbo system should be checked and replaced by a valve.
08.05.2020 20:54 # 5
Baver Diyar
I wrote the turbo Egr as the one whose air flow sensor or something has changed and in vain, don't look anywhere else in the 100% fuse box they said it was chronic.
08.05.2020 20:54 # 6
Baver Diyar
I changed the turbo valve 3 times, they were all empty.
08.05.2020 20:54 # 7
savasdemirci
Hello friends, I changed the fuse box unfortunately the problem is not solved. There is a situation like this, after putting the car in the dyno test, the car is almost dead. I put it in the test after the fuse box, the first test was 60hp, now it is 94, but the test output started to crawl again.
08.05.2020 20:54 # 8
Let's summarize the operations done as follows.
1-turbo solenoid valve changed (same situation)
2-flow meter changed (case is the same)
3-fuse box changed (same situation)
Let me ask you now, the vehicle's diesel filter and diesel pressure sensor are checked. As our friends said, I was measuring turbo pressure. Is there a situation such as burning oil - water reduction in the vehicle. engine ecu sockets checked.
I also have solutions for those who have the same problems as you are. And which master in Ankara do you go to?
08.05.2020 20:54 # 9
savasdemirci
[QUOTE = sonerkyl] now let's summarize the actions done
Diesel filter has changed recently, diesel pressure sensor has changed recently, there is no oil burning water reduction, ecu sockets checked, turbo valve cable line renewed. It looked solid where the friend on the link described it. I went to all of the brothers (special), Self icon (special), Fatih (Authorized).
It is difficult to persuade the men because the vehicle is sometimes doing it or not doing it.
08.05.2020 20:54 # 10
I understand, my brother, you had a lot of trouble. Also, be careful to check these problems in the rain or hot weather. The problem seems to be electrical, leading me to take a break from time to time. When the services fail, they usually say that there is nothing. Could you have the gas pedal sockets checked? In addition, crank speed sensor sockets etc. Oil-free contact spray-clean. Finally, when this problem occurs, they never have it connected to the diagnostic device. I mean.
08.05.2020 20:54 # 11
savasdemirci
Fault finding device is giving error P0299. Seeing this error, the turbo is replacing the valve, the electrician says in his test program that the error code of the valve is different about this turbocharger pressure loss, but we still haven't found it. Next, there are injectors and brain replacement processes.
the savasdemirc 2018-06-08 17:23:52
08.05.2020 20:54 # 12
[QUOTE = savasdemirci] The fault detection device gives P0299 error. Seeing this error, the turbo is replacing the valve, the electrician says in his test program that the error code of the valve is different about this turbocharger pressure loss, but we still haven't found it. Next, there are injectors and brain replacement processes.
If you want young masters, if you want to go through an emrah and soner from an ankara peugeot 308 group, you do not need to do anything, you will get information and meet. They are good at Peugeot. ivedik 1333 cd 1344 sk no: 48
fault detection with original software or a universal device. sometimes universal devices may not show some fault codes.
sonerkyl 2018-06-08 17:36:41
08.05.2020 20:54 # 13
savasdemirci
[QUOTE = sonerkyl] [QUOTE = savasdemirci] The fault detection device gives P0299 error. Seeing this error, the turbo is replacing the valve, the electrician says in his test program that the error code of the valve is different about this turbocharger pressure loss, but we still haven't found it. Next, there are injectors and brain replacement processes.
Thank you for your interest and help. I will go to Mass at the first opportunity. Authorized and special service with the original software, electrician friend looked with bosch software. All of them are p0299 but open to interpretation.
the savasdemirc 2018-06-11 13:44:14
08.05.2020 20:54 # 14
tbayder
selcuk bey hello. I am new, I read the conversations even more.
08.05.2020 20:54 # 15
savasdemirci
[QUOTE = tbayder] selcuk bey hello. I am new, I have read the conversations even more, this is stuck, I have this question in my head. The vehicle is in trouble and does not pass 3000 rpm. The gear does not matter [/ QUOTE]
Hello, your situation seems to be related to turbo. As if there is a problem with the turbo or turbo system.
08.05.2020 20:54 # 16
savasdemirci
[QUOTE = savasdemirci] [QUOTE = sonerkyl] [QUOTE = savasdemirci] The fault detection device gives P0299 error. Seeing this error, the turbo is replacing the valve, the electrician says in his test program that the error code of the valve is different about this turbocharger pressure loss, but we still haven't found it. Next, there are injectors and brain replacement processes.
I went before the feast, but they were too busy they couldn't look. By the way, I had minor bonnet problems, so I left it to the industry, and when I finished, I will try my luck :)
08.05.2020 20:54 # 17
serdarr4
I have the same problem. I have not left. If you found a solution, please reply.
08.05.2020 20:54 # 18
ismailkaya
I do not understand much from the vehicles with the bosses, but I guess where the problem may be, the upper and lower sensors in the catalytic converter send commands to the brain for the engine to function properly, there may be injector obstruction, and the engine in the butterfly throat may not perform properly or it may be a program in its alternator.
08.05.2020 20:54 # 19
Selcuk55
Tbayder It's a little late brother, but the flow meter malfunction of the problem LOL Selçuk55 2018-07-19 00:11:50
08.05.2020 20:54 # 20
savasdemirci
Thank you guys, the top cover has been removed, everything you can think of has changed, just in case I changed the insurance box. Injectors, timing, radiators, even radiator fans changed, the turbo was revised. It is better than before, but it is not like the first day. Of course :( I was going to darken my eyes and buy a zero engine. the savasdemirc 2018-08-28 11:05:44
Page : / 2
