Performance increase without disturbing the originality of the vehicle |
| • Homepage » PEUGEOT MODIFIED PLATFORM » 206 | |
| 08.05.2020 19:57 | # 1 |
| 08.05.2020 19:57 | # 2 |
sonerkyl |
As you said, you will have enough oil-oil filter - air filter - pollen filter - spark plugs and gasoline filter.
| 08.05.2020 19:57 | # 3 |
Thank you, Soner. But if we use a different air filter, is it possible to increase performance without increasing fuel and damaging the vehicle?
| 08.05.2020 19:57 | # 4 |
Not my teacher. If you want performance, you will have to take the fuel off. It doesn't play too much, it plays at most 5 krş, it varies according to usage. In addition to the words of Soner brother; Cancel the EGR valve with blind seal, cat. You will feel obvious relief in the empty vehicle.
| 08.05.2020 19:57 | # 5 |
A friend put a video on YouTube. He has the same vehicle as me. He said that when he used his car with an open air filter calmly, there was no change in fuel, but there was a noticeable increase in performance. How true is this in your opinion? 0-100 of my vehicle is shorter than factory data in any way, but it still does not satisfy me. |
| 08.05.2020 19:57 | # 6 |
I have never tried to install an open air filter, so I will not be able to comment fully, but I do not think that there will be an increase in fuel in calm use. They say that when I cancel the EGR, the fuel increases, my vehicle has a 0.2lt decrease in average fuel. In addition, 1.4 70 hp vehicles teacher don't expect a performance, our economy car is ours :)
| 08.05.2020 19:57 | # 7 |
maximusti |
As your friend said, not much is expected from a 70 hp car. If you do periodic maintenance, your car will be more comfortable, your acceleration will be shorter, In addition, you can have EGR and cancellation of the floor, and there are those who suggest it, Additionally, if you increase the rim size, your road behavior increases (comfort decreases) |
| 08.05.2020 19:57 | # 8 |
Increasing the rim size negatively affects acceleration. There is no comfort anyway, I know the bad roads in my city. I open the music in second gear and go in the aheste. I can't break it in the car, actually. ![]() I know what the vehicle is, I am not expecting much performance. But if there is something that can be done at affordable cost, I want to do it. At the moment, 70 defects are producing hp power, so it was in the expertise. If I do this 85, it will increase enough if the possibilities allow.
| 08.05.2020 19:57 | # 9 |
friends, software, turbo etc need to get into business, but with these you better sell it and get 206 gti
| 08.05.2020 19:57 | # 10 |
My vehicle is currently under maintenance Printing pad Engine oil Oil filter, air filter, pollen filter, gasoline filter spark plugs The timing set is changing. There was a click coming from behind, and they would handle it. I think it will be finished by noon tomorrow. I changed the lpg brain and lpg filter a week ago. Let's see if there will be some relief and increase in performance. Clean thousand lira went by the way
| 08.05.2020 19:57 | # 11 |
sonerkyl |
[QUOTE = alicelik20] My car is currently under maintenance Printing pad Engine oil Oil filter, air filter, pollen filter, gasoline filter spark plugs The timing set is changing. There was a click coming from behind, and they would handle it. I think it will be finished by noon tomorrow. I changed the lpg brain and lpg filter a week ago. Let's see if there will be some relief and increase in performance. Clean thousand lira went by the way [/ QUOTE] Make sure you have the best vehicle, Ali vehicle will be different. meanwhile, don't forget to replace the circulation pump
| 08.05.2020 19:57 | # 12 |
My vehicle will be available at noon tomorrow. I also told the master the circulation pump, but my master insisted first let me check it, do not make a cost. I expect to see a noticeable increase in traction in my vehicle after these procedures, I hope I am not disappointed. If it turns out as I expected, I will shoot 0-100 videos maybe
| 08.05.2020 19:57 | # 13 |
sonerkyl |
Do not look at the master, change around 80-100 TL, then the piece with 80 TL will fail and get a harder clean job that will require 100 lira of labor.
| 08.05.2020 19:57 | # 14 |
outlaw |
I think the cleanest mod you should do If the 1-boiler air filter does not increase the fuel, if you press it to hear sound, the fuel will increase. 2-catalyst cancellation 3-If the engine is intact, flat pipe of 51 (chrome is much better) 4-sonada performance exhaust (like otto hks remus ss magnum) If you did these things, your car would be like a monster.
| 08.05.2020 19:57 | # 15 |
It would be wrong to expect something too much from a 1.4 75 hp gasoline engine, so I advise you not to do anything for it.
| 08.05.2020 19:57 | # 16 |
EGR valve and catalyst cancel cause engine to run hotter. I researched this issue for a long time. It requires a better separate cooling for the engine. It significantly reduces engine life in long use. Therefore, I eliminate the second option directly. I need to investigate the others. ![]() After carrying out the operations I wrote above, there was a problem with a low rotation speed and no gas. It doesn't do it all the time, but it does it at certain intervals. Could it be something related to lpg?
| 08.05.2020 19:57 | # 17 |
sonerkyl |
Ali bro, just be informed, egr is only in turbo diesel vehicles. Idle speed and RPM adjustment - from throttle and idler engine. these are the main factors, there are intermediate factors, unchanged filters, poor quality fuel defective sensors, rupture in air filter temperatures etc.
| 08.05.2020 19:57 | # 18 |
This was not a problem before servicing the vehicle. Can these things happen or could it be caused by a master's error? If I do not go to have the Lpg setting soon
| 08.05.2020 19:57 | # 19 |
sonerkyl |
Such maintenance may occur after maintenance. you get a lpg setting
| 08.05.2020 19:57 | # 20 |
I took it back to the master. He put some heart. He said it might be because I washed the car's engine, if not a little thousand, I will do whatever it takes. As Gökha explained in a little bit, what do you expect from this vehicle, it comes to me so 206 your car is good, these vehicles go so much, he said. In the meantime, I have to thank Soner very much, thank you very much for your help.
