peogeot 307 trip computer
08.05.2020 18:49 # 1
samet33
Hello friends, my trip computer is not visible in the daylight, but can only be seen in the headlights.
08.05.2020 18:49 # 2
Antiseptiq
Hi chronic problem, you will find hundreds of topics from google ...
08.05.2020 18:49 # 3
Zzeskin
There are 3 bottomless bulbs behind the trip computer screen. The same had happened to me. I changed the two of them exploded, there was no problem.
08.05.2020 18:49 # 4
Alicilik
There are 3 bulbs in the background, as the friend mentioned, make them stronger.
08.05.2020 18:49 # 5
xmen
friends, what you call this light bulb is different in my car ... there is no light bulb ... it should be led ... I have a fading in the heat ... I have a solution other than changing the screen ....
08.05.2020 18:49 # 6
riderzist
They say you can disconnect the bulbs and pull the led strip with soldering, it is more stable. If I can find a topic in the forum, I will share it here.
08.05.2020 18:49 # 7
xmen
[QUOTE = riderzist] You can disconnect the bulbs and pull the led strip with soldering, they say it is more stable. If I can find a topic in the forum, I will share it here. [/ QUOTE]
I searched and scanned but I couldn't find it ... thanks for your help ...
08.05.2020 18:49 # 8
hozer33
Do you recommend that led light business?
08.05.2020 18:49 # 9
KILIC
LED light is not a solution, my teacher is the problem of the screen. I made the led, but again, the screen was not read in the same way, even since the led was not read, the led lights were visible in the back, as the articles were not read in the hot. I think never get infected. The 206 screens were one to one and were sold from them, and if I remember correctly, it was around 200 TL. Of course, you can make it more suitable than aliexpress.
