Pejo307
08.05.2020 20:45 # 1
Safak
Hello friends, I have a 2007 car, it was very cold in the past, we did not work, we did not press the battery, we did not work, we did not work, we changed the battery again, we did not again, we did not connect to the computer, we connected the genie with a financial device, it found the tip of the catalytic system, under the nerves, look at the second one, look at the fuel, say the fuel, the fuel is the problem, it says poorly. If I change the problem, will it be solved?
08.05.2020 20:45 # 2
First of all, welcome to us. Search. If gasoline is more likely to make it from the pump, do not drop your fuel level below the half tank. Catalatic convector does so if malfunction may be clogged. If there is space like a closed garage, pull the car over there and heat it and try it. Also use the recommended engine oil 5/30 or 0/30
08.05.2020 20:45 # 3
Safak
Hello, how the pump works, how to decompose the catalytic convector supply, I changed the battery of the car and then the triangle mark appeared on the panel, so it still exists.
08.05.2020 20:45 # 4
Hodja, I have to disassemble and look at it and now I add the diagram of the place where it is located. either you will empty your inside, of course there is a problem with the master who will do this work or you will replace it with a piece.
08.05.2020 20:45 # 5
Safak
tesekürler
