Pejo206 X line petrol lpg stop problem
08.05.2020 20:41 # 1
furkanpatir
Selamünaleyküm friends I have a 2004 model 206 x line vehicle. My car stops when the engine is warming up, so when the temperature indicator reaches 90, I am kicking and stopping while I am on the road. There is no problem in running after the vehicle engine has cooled down. I did not understand I took it to a few masters. If you have an idea, I would be glad if you could help.
08.05.2020 20:41 # 2
First of all, welcome to us. If you give some more information, is the car gasoline - LPG if it is benzene - or diesel?
08.05.2020 20:41 # 3
furkanpatir
I brothers, the car is having the same problem when I go with gasoline and LPG only gasoline.
08.05.2020 20:41 # 4
I can give advice like this, brother.
1- It closes the LPG system from fuse. Close the LPG valve in the tank so that the gas does not come to the engine.
Use it in 2-150-200 km gasoline. Do you observe the same problems or is there any improvement?
3-If it continues after 150-200 km, the places where you will have priority control are coil-gas filter and gas pump.
08.05.2020 20:41 # 5
furkanpatir
Thank you bro, I hope you will try what you say and share the results.
