PEJO RIGHT SIGNAL MADE
08.05.2020 21:21 # 1
Pejoant
& nbsp; Hello friends. I'll explain the incident from the very beginning.
While the right front signal is blinking fast, the rear turn signal lamp never lights up. What might be causing the problem? I wonder if there was a connection because I forced it? or is the fuse or something wrong? thank you in advance
video & nbsp; https://www.youtube.com/watch?v=swCoJU9qOJA < / a>
08.05.2020 21:21 # 2
Pejoant
UPDATE ++
08.05.2020 21:22 # 3
First of all, check your light bulbs and the first option comes to my mind. Secondly, there may be a problem in the signal arm. it will be necessary to disassemble and check.
08.05.2020 21:22 # 4
iso0625
This rapid combustion is usually a sign of a broken bulb. One of the signals on that side is breaking out, whatever side is burning fast to inform the driver. Probably right rear burst, replace your signal bulb.
08.05.2020 21:22 # 5
bilo131
[QUOTE = iso0625] This fast-burning event is usually a sign of a broken bulb. One of the signals on that side is breaking out, whatever side is burning fast to inform the driver. Probably right rear burst, replace your signal bulb. [/ QUOTE]
I definitely agree +1
The problem will disappear when the bulb that is broken changes.
08.05.2020 21:22 # 6
Pejoant
thank you very much friends. I will buy a new bulb and try it.
