pejo 407 timing change ...
08.05.2020 19:06 # 1
407 ERHAN
friends, pejo 407s I have a timing belt or chain, as far as I know the timing chain does not change, but the belt is changing, I do not know if my vehicle is currently changing at 168,000 km, how can I find out if it should be changed, and how many thousand of them have to change. ?
08.05.2020 19:06 # 2
Faruk
the service history is obvious or needs to be dismantled and the room is hard work.
normally 1.6 hdi varies in 120 thousand.
I'm waiting for 240 thousand right now for the second.
If you cannot find it in the service record and the previous owner does not know exactly, replace it. Your job will be solid.
08.05.2020 19:06 # 3
407 ERHAN
thank you faruk brother, when i got my car it was at 167.500 km, now it is 168.000, probably it has changed by this time, because if it should change at 120.000 km it is impossible to arrive unchanged by this time, but what if the timing set and labor cost on average wonder how much it costs?
08.05.2020 19:06 # 4
Faruk
If the vehicle changed hands until it came to you in the meantime, it may have not changed.
As I said, it must be removed from the service record.
I looked from the net now the timing set 170 is original.
It should be done around 250-300 with workmanship.
I have changed a lot.
new friends or master friends will tell you the net price.
If I could not find a service record, I would change it, I would give it 250-300 and I wouldn't leave it to chance.
Good luck with.
08.05.2020 19:06 # 5
407 ERHAN
You are right faruk bey, thank you very much for your interest, I will show it to the service as soon as possible, thank you friend, good day ...
08.05.2020 19:06 # 6
EYESMAN
The km change period for your diesel vehicle is 10 years or 180.000 km for heavy conditions. Services say 120.000 km for 5 years. One of my friends had 407 untouched trig at 150,000 km and it had just changed. If I was you, I would change it if I don't know its past. Since I made my own 308 hdi vehicle, I just changed at 90,000 km and gave 35 lira for the cost. Peace of mind .. EYES man 2015-02-18 17:26:50
08.05.2020 19:06 # 7
407 ERHAN
ok eyesman my friend, thank you very much, you are telling the truth, i will change it as soon as possible, see you, good day, kib ...
08.05.2020 19:06 # 8
ysf_syfttn
I have 2006 model 206 friends, will the timing change be 120 thousand so mine is 107 more thousand?
08.05.2020 19:06 # 9
Faruk
[QUOTE = ysf_syfttn] I have 2006 model 206, guys, will the timing change be 120 thousand, so mine is 107 thousand more? [/ QUOTE]
1.6 hdi 110 timing varies every 120 thousand times.
The service knows how many thousandths it will change according to your engine or you know your experienced friends.
08.05.2020 19:06 # 10
themurat54
I guess that it will change after a 60-70 thousand bed in 206s. my 77 thousand has changed, the master said we would change 140 thousand again
08.05.2020 19:06 # 11
407 ERHAN
When the timing belt is worn and it is time to change, it makes a sound, it becomes clear, some masters say, what should we do, continue until the sound comes ...
08.05.2020 19:06 # 12
msty_35
[QUOTE = 407 ERHAN]
When the timing belt is worn and it is time to change, it makes a sound, it shows itself. My 307 vehicle broke the trigger when it was 165000 km. While this damned belt is normally installed around 250-300, including workmanship. It can damage valves due to the eccentric shaft, tensioner bearing, crankshaft and pistons that it is attached to. Don't make the mistake of me. Change it now.
08.05.2020 19:06 # 13
emreeee
friends what do you recommend as a brand original 170 to 130 gates 100 lira but there are also ina brand outlets
08.05.2020 19:06 # 14
407 ERHAN
friends, there are those who say that this timing belt makes a sound when it is time to change or when it loses its old feature, there are those who say that it does not make a sound or suddenly break out.
08.05.2020 19:06 # 15
baybaba
No sound, no timing belts on the timing belt, no wonder, look at 3-5, if possible
it changes to the service, it is not like other parts, if it breaks, it will cost at least 3-4 thousand liras,
08.05.2020 19:06 # 16
xmen
[QUOTE = 407 ERHAN] friends, there are those who say that this timing belt makes a sound when it is time to change or when it loses its old feature, there are those who say it does not make a sound, suddenly, a friend who will definitely inform me about it or have a similar experience. Is there any? [/ QUOTE]
Recently a friend's car had broken off the timing belt on the forum, the vehicle stopped on the way, they only understood what was in the repair shop. so don't wait for the triger to sound like this .. if you don't know the situation, change it. If you change around 500-600 pounds in service, they will replace all the parts that need to be replaced.
xmen 2015-03-12 21:06:47
08.05.2020 19:06 # 17
Mustafa-almanya
In my 90 model golf, when the car was at 92000, the timing was broken, the mechanic made a sound, the fuel increased. However, these symptoms had none. In my Clio 2 diesel vehicle, the engine is running very loudly, the mechanic said that the engine balls and the camshaft are gone. The vehicle is running hard, but the mechanic said that he can stay on the road at any time. I was using the wheel balls. I looked at the service book today, there are many more kilometers in the timing change, but they wrote every 5 years. My clion was 7 years. I don't know if the current engine failure could have been from the timing. I hope my experience has been useful, Erhan.
08.05.2020 19:06 # 18
407 ERHAN
ok guys, I will follow your advice, I shouldn't leave the chance to work, I bought this vehicle just 2 months ago, now 168200 km, the friend who sold this vehicle to me also used it for 1 year before me but it did not change the timing belt and before I don't know when it has changed or whether it has changed, you will understand the situation as a little bit grave, the best thing is to change and get rid of it, as you say, no need to ride the vehicle with fear, let me feel comfortable, I offer my greetings, my respects, thank you very much to my friends who write answers one by one. Thank you, friends ... :)
