Pejo 308 2008 vti engine
08.05.2020 21:22 # 1
AslaneA
friends, I want to ask good evening even though they say pejo 308 vti motor vehicle.
08.05.2020 21:22 # 2
omerb
hello I did not use vti motor lu vehicle. But because there is no problem motor. When I look at the ads there are about 150 vehicles for sale. I think it started to be produced in 2008! Since it is not for sale in the market, I guess it does not cause much trouble. The factor here is the master you went to. I think nothing will happen if you buy a full-service vehicle. If you buy a car that's been played here, wow.
I hear a lot that the masters who understand from Vti engine are limited.
You can use your vehicle properly and maintain it completely. Use the vehicle occasionally, instead of once a week. I hope you ride smoothly. Pleasantly ride a thousand. I already think it is a troubled engine.
08.05.2020 21:22 # 3
AslaneA
I think of it too, I also pay attention to its maintenance, for your information
08.05.2020 21:22 # 4
I used 308 1.6 vti for 2 years, teacher. It is very important that the maintenance of the vehicle is sufficient on time and not suitable for the engine, and that it is suitable for the vehicle. some masters put 10/40 oil or 150 km of the vehicle and this engine kills over time. My advice will be this.
1-motor absolutely full synthetic 5w / 30 oil put motul - liqui moil quality brands. To minimize this (due to the nature of the engine) because vti engines have oil reduction.
2- The filters are absolutely original (affects the vehicle's performance)
3- Always replace your spark plugs every 2 days.
4- If your vehicle has LPG, use it at 100 km per month and do not disrupt filter maintenance.
5- Disassemble the eccentric solenoid valves in 3 treatments and have them cleaned.
6- If the v-belt is not neglected, replace it.
7- Never use your vehicle without antifreeze.
8- Bakelite on the glass under the wipers does not fit properly. Ensure that it is fully seated. Engine - fuse box and coils cause water to flow.
9- Change the brake fluid probably has not changed for a long time.
10- Do not neglect your pads and discs, the braking distance has an effect. If it is too thin, cracks may have occurred.
11- Do not neglect tire air, not under 34 psi.
08.05.2020 21:22 # 5
AslaneA
thank you for the information you provided
