PEJO 307SW MARK PROBLEM
08.05.2020 20:55 # 1
KENAN_IZMIR
hello friends 2006 my diesel car has a margin problem happened to me 2 times in the past days i mean 1-2 months ago the same malfunction of the starter dynamo charge also changed the starter fluye but again the malfunction repeated malfunction information when I turn the ignition, the lights on the show are all on, ceiling lights are on your opinion what kind of malfunction can there be .. starter? battery?
08.05.2020 20:55 # 2
Have your battery measured, hodja.
08.05.2020 20:55 # 3
onlycihan
Even the most exhausted version of the battery can burn the indicator tape and vehicle lamps, but it may not be enough in situations such as the starter that requires power. The easiest and cheapest method to measure the battery is to find the fault.
08.05.2020 20:55 # 4
Kysr038
I experienced the same situation in winter.
I hit it and started it mine, because it was gasoline
I went to the industry, I changed the battery
No problem
08.05.2020 20:55 # 5
ismailkaya
if there is no function in the starter, possibly all electrical functions of the vehicle are working
sensor but which one? I think there is a lack of contact with the sockets Remove the bonnet of the car Check all the sockets, including sensors under the air filter, if you do not understand, manually control the sockets of all the terminals of the electrical wiring
08.05.2020 20:55 # 6
KENAN_IZMIR
problem solved. Thank you very much to the friends who wrote .. I changed the battery, I did the battery measurement as if there was no problem, signaled to replace the battery box .. the auto electrician took my money in vain .... we received 160 TL in the charge bulusei + took 100 workmanship ... I do not understand who we will trust .... Angry
08.05.2020 20:55 # 7
Ahmet Bektas
measure the battery Ahmet Bektaş 2018-06-19 21:47:37
