Pejo 307 plumbing short circuit ie brain malfunction |
| 08.05.2020 20:08 | # 1 |
| 08.05.2020 20:08 | # 2 |
ggitaristt |
3000 cycles means protection mode. When there is a problem in the engine running, the turbo shuts down and the engine does not exceed 3000 rpm. asr abs esp error writes on the screen. I came across a problem (bent one by one) after hitting a small curb. While racing, the turbo did the same from overload. To comment, it is necessary to connect to the computer and look at the fault codes. |
| 08.05.2020 20:08 | # 3 |
sonerkyl |
When my teacher says the brain, which one is bsi or ecu, which one is malfunctioning.
| 08.05.2020 20:08 | # 4 |
pepecura |
turbo can also be faulty
| 08.05.2020 20:08 | # 5 |
sonerkyl |
In fact, they said the turbo was solid, but if I checked their homosexuals, let me ask him.
| 08.05.2020 20:08 | # 6 |
I'm not sure, but I guess the ECU is next to the insurance
| 08.05.2020 20:08 | # 7 |
Continued appilattion fault error. The bit and motor light are on because of this. Bidet gives abs fault error but the light does not light up gives way pc errors
| 08.05.2020 20:08 | # 8 |
Friends, I am going to Istanbul to buy 8 vehicles at 19 in the morning. I am writing to help somebody. Before the vehicle was ready, the vehicle gave 4 errors when we connected to the pc, the accumeter was too much and the acismeter was giving short circuit or open circuit roles of course irrelevant but short circuit open circuit errors. I looked at the particle, so I had to cancel it, I changed the flow meter, the tool was not updated, but we connected it to the PC again. The car is not over 3000 cycles again. Master brainwheel, that is, the short circuits damage the brain.
