Pejo 307 - Is this sound coming from the engine normal? (VIDEO)
08.05.2020 16:35 # 1
kuantum
I noticed a strange noise coming from the right front (by the crank pulley) of my car. I recorded this on the video, have a look, is this sound normal? If not, what is the problem? My previous 307 didn't have this sound ..
[TUBE] http://youtu.be/WeJVYt7eRJA [/ TUBE]
08.05.2020 16:35 # 2
yavuz25
So, while this is the sound, does the engine speed fall and go in connection with the sound?
08.05.2020 16:35 # 3
kuantum
my car is automatic, and this happens when the car is idling. Frankly, I did not look in. What does this mean if the cycle is falling or getting up?
08.05.2020 16:35 # 4
yavuz25
Then check it out and see if it sounds, does it play in the cycle turbo. When I give gas, for example, when it is running idle at 2000 cycles. "Wink" title = "Wink" />
08.05.2020 16:35 # 5
kuantum
Okay, I'll look at the first opportunity. If you still have what you said, can you tell me what happened? I was very curious. "Clap"
08.05.2020 16:35 # 6
yavuz25
If it doesn't work, my brother is singing. "Wink" Either you drive it from the belt spray or you will change the belt. If I say I need to examine it in more detail. need to show the master
08.05.2020 16:35 # 7
06OzGuR06
Does this engine work like diesel & nbsp; It seems to me that there is an irregularity in the engine speed. "Ermm"
The belt may be wobbling. "Smile"
06ÖzGüR06 < editDate> 2012-02-13 13:14:01
08.05.2020 16:35 # 8
yavuz25
there is a slight sound yes my brother is running. "Wink"
08.05.2020 16:35 # 9
kuantum
[QUOTE = 06ÖZGüR06] Does this engine work like diesel & nbsp; It seems to me that there is an irregularity in the engine speed. "Ermm"
Voice strap sound The belt may be wobbling. "Smile"
Yes As if there is sound coming from the belt. At the same time, it started to sound like diesel recently. I said it might be cold. There may be an irregularity in the engine's operation, it may be due to idling & nbsp;. By the way, which strap do you mean by strap? & nbsp;
08.05.2020 16:35 # 10
06OzGuR06
[QUOTE = quantum] [QUOTE = 06ÖZGüR06] Does this engine work like diesel & nbsp; It seems to me that there is an irregularity in the engine speed. "Ermm"
Yes As if there is sound coming from the belt. At the same time, it started to sound like diesel recently. I said it might be cold. There may be an irregularity in the engine's operation, it may be due to idling & nbsp;. By the way, which belt do you mean by belt? & nbsp;
If you want to have a look at it from the V-belt, that is, the V-belt. = "smileys / smiley1.gif" border = "0" alt = "Smile" title = "Smile" />
08.05.2020 16:35 # 11
yavuz25
[QUOTE = 06ÖGGR06] [QUOTE = quantum] [QUOTE = 06ÖGGR06] Does this engine work like diesel & nbsp; It seems to me that there is an irregularity in the engine speed. "Ermm"
problem can be from the alternator belt. It is checked according to the situation. "Smile"
08.05.2020 16:35 # 12
Idling is unbalanced. Get on your vehicle for half a while with petrol.
08.05.2020 16:35 # 13
yavuz25
[QUOTE = laedri] Idling unbalanced. Get on your vehicle for a while with half tank gasoline. [/ QUOTE]
The belt that shows the idle unbalanced may also be the sound. I thought you are right, but it will be much more beautiful if it is determined from the tachometer. "Thumbs
08.05.2020 16:35 # 14
kuantum
Well, now I went out and checked the final situation. The sound in the video is now lost. I looked at the period. there is not the slightest play in the era. The situation is steady. In this case, what might this sound be about. I went to the gas station and put 5 liters of gasoline, the car even worked hard with it. I barely started the car. I waited a while, my vehicle automatically switched to LPG. At that time, I shot this video. When I recorded this sound, the vehicle switched to LPG ..
08.05.2020 16:35 # 15
yavuz25
It is most likely that the belt blasts. It would be continuous if something else happened. It would be better if you had the engine running towards a master. It didn't sound good to me. "Wink
08.05.2020 16:35 # 16
He created himself without knowing that sound coming out of his friend vehicle. Gasoline was finished, gas pump was distracted, idling was surprised. But after a while it got better with gasoline.
08.05.2020 16:35 # 17
ByHack
If it has just switched to LPG and is like this when the engine is cold, & nbsp; this can be idle imbalance. The main reasons for this are spark plugs-spark plug cables & nbsp; and & nbsp; LPG filter. I would say if he did it all the time, so if the engine did after warming up, it could be from & nbsp; LPG calibration. I think the belt sound is normal in idling fluctuation, and especially below the standard idling speed in the cold, because this has happened to me too, and it does not change from time to time, as it does not replace the spark plugs (no problem in gasoline or after the engine warms up) & nbsp; A slight whiskey sound may also occur when first running and fluctuating. . In addition, when the engine suddenly presses on the gas, it must be in a state as if the engine is drowning. But, as your friends said above, it is better to go to a master anyway like engine sound etc. At least you can confirm it from the places I said :) Come on greetings ... ByHack 2012-02-13 23:29:23
08.05.2020 16:35 # 18
by_nefretimsin
slm the vehicle's authentic belt ball may not be from the belt I do not think it does not make gasoline show to master
08.05.2020 16:35 # 19
ismail ozdemir
It's not the belt sound, but since the cold starts, this is the engine of the snarling engine that sounds like diesel, but there is no idling problem.
08.05.2020 16:35 # 20
emin15
The engine rpm rises and rises, the throttle body body cannot be idle, can not stop at idle, when it is cold. The sound coming from the engine is from the tiriger belt or the circulation if the noise required to remove and restart the alternator belt continues.
