PEJO_307 DEPARTURE PROBLEM
08.05.2020 16:29 # 1
bysnip06
FRIENDS HELLO,
& nbsp; 1 WEEK BEFORE I BUY THE 2004 MODEL 307 XT (LOVATO BRAND LPG SYSTEM) MODEL BUT I HAVE EXTREMELY LIKE A PROBLEM THAT I HAVE EXTREMELY LIKE A PROBLEM - THERE IS A REALLY LIKE THAT I HAVE A REALLY LIKE A PROBLEM. DOWNLOAD STOP (NO TROUBLE AFTER 3000 SPEEDS)
- IN THE PREVIOUS VEHICLE I WAS RELAXED IN THE 2nd VEHICLE WITH COMFORT (1996OPELASTRA).
DOES I HAVE PROBLEMS LIKE THIS SUBJECT, IF YOU ARE HELP, I WILL BE A GUEST.
RESPECT,
08.05.2020 16:29 # 2
yavuz25
The second gear is on the bippers and knows what's going on.
08.05.2020 16:29 # 3
bysnip06
I haven't taken it in a way yet, it's been 1 week since I bought the vehicle & nbsp;
08.05.2020 16:29 # 4
yavuz25
I think it is better to have a maintenance done. "Wink"
08.05.2020 16:29 # 5
albayman
I think there is a problem in the ignition system if the half-clutch is shaking, not eating and shaking or stopping if the vehicle is lifting or trying to move in 2nd gear at low speeds. If nothing happens on the computer, the butterfly throat should be cleaned with an injector, the spark plugs should be renewed if their cables are worn, the coil ignition should be checked ...
I don't like to give too much gas when lifting the car. I lift between 1000-1500 revolutions. I'd have to stop and shake me too. butterfly throat cleaning would fix this problem. very comfortable now ...
08.05.2020 16:29 # 6
fTh206
[QUOTE = yavuz25] I think it is better to have a maintenance done. "Wink" [/ QUOTE] take me to a maintenance tool
08.05.2020 16:29 # 7
albayman
Even if you specialize every second hand of a hand-picked vehicle, I think you should not trust the previous user & nbsp; to ride comfortably:
oil, oil filter, air fuel filter timing water pump ...
extra spark plugs
When I bought this vehicle, the previous owner said that the km is still small for the timing, we use it like this. service mileage is low, but the year has come. I changed it, well, I changed it. a lot of cracking has started in the strap. there was an imbalance in the bearings.
08.05.2020 16:29 # 8
bysnip06
First of all thank you for your comments, & nbsp; This morning, I realized that I do not have such a problem in gasoline, so even if I do not press the gas, the car continues to move, when I leave the gas when it passes to LPG, it falls from the cycle. Do you think it has an expensive expense? Is there a master you can recommend in Ankara?
Regards ...
08.05.2020 16:29 # 9
albayman
gasoline engine is made according to this fuel, does not cause problems in gasoline. Since petrol is also a better and specially different fuel compared to LPG, the engine's small engine problems may not reveal themselves. For this reason, some problems start to appear in vehicles that have LPG after 100 km. more precisely, after the application of LPG, the positive and negative of the engine is gradually understood.
08.05.2020 16:29 # 10
yavuz25
I do not think it will be expensive, man. "Wink"
08.05.2020 16:29 # 11
ByHack
yes friends, I am having the same problem in this lpg event. Especially in LPG and low revs, it shifts in gear changes. They said it could be from the lpg filter and its calibration. I will take this weekend and ask the master about this situation and write the answer. I hope it will not be a big problem salute ...
08.05.2020 16:29 # 12
bysnip06
[QUOTE = ByHack] yes guys I have the same trouble in this lpg event. Especially in LPG and low revs, it shifts in gear changes. They said it could be from the lpg filter and its calibration. I will take this weekend and ask the master about this situation and write the answer. I hope it will not be a big problem greetings ... [/ QUOTE]
We are waiting for your news, hodja
08.05.2020 16:29 # 13
BurakGONULAL
LOOK AT THE FIRST RELAX SETTINGS AFTER I HAVE A DIFFERENT CUTTER OF LPG, I DO NOT KNOW THE BRAIN WITH THE BRAIN.
08.05.2020 16:29 # 14
bysnip06
Do you know a good quality cheap road master in Ankara?
How much does this car cost on gasoline (307 1.6 2004 xt)
If you are driving, I would be happy if you write the forecast. Today, I called a master in my ost pejolar lpgde
It creates trouble, always the case feels heavy, I recommend you use it on gasoline, I do not know how accurate or he could not trust himself.
