pejo 307 automatic transmission error?
08.05.2020 19:51 # 1
Mur@t
Hi;
3 months ago I bought a pejo 307 xt auto petrol + lpg car, for the past 1 month sometimes the snow and sports mode lights are flashing on the gear indicator otom . It gives a gear fault error, it gets better when the car stops and restarts.
Usually the error can come out while standing at the red light and back and forth to park.
My vehicle is at 140 thousand kilometers.
I showed it to the automatic transmission master on the Maslak auto industry site today. connected to the computer and the following errors appeared:
1.fault in pressure regulation variation recommendation.
2.CAN engine torque information no signal
3.multi function switch signal fault. inconsistent position
According to these errors, the master said, the solenoids and the position switch and the oil will change will all be the original parts, there will be a fee of 800 TL. If it does not improve, a complete revision is required 2500 TL.
Then let's look at the oil, if there is a burning smell, the pads may have burned, and they looked, they did not smell burns, probably the pads are intact, sometimes we may not get the smell, but if there is no such thing, we will do the first thing I said.
accordingly, should I do this first operation? or what would you recommend based on your experience? I wonder if I show it to another master. ??
08.05.2020 19:51 # 2
talip206
Your master said it right. although not certain it does because of 90% solenoids. But in any case, there are 10 percent other possibilities. But the first thing to do is change the oil and solenoid. Unfortunately, late or no gearbox, solenoids can malfunction due to oil change. It's an average price when it comes to price, but try to bargain. The cost of the master is around 300 pounds, and the rest takes workmanship. I had it done in Ankara in the previous year with 500 bargains. According to the master, there are places between 600 and 1000 TL.
The life of the pads is more than my transmission life. however, if the oil has decreased, the pads will burn. otherwise, the linings do not cause problems. But it was good to check.
talip206 2016-06-23 00:58:23
08.05.2020 19:51 # 3
Mur@t
Thank you for your answer, aspire ...
This price is included in the electronic part they call Multifunction swicht, which adjusts or determines the position of the gear called position switch.
just said 250 TL for this piece price ... right price ...?
Also, the subject I want to get your main idea is that he does not know about new type of solenoid and software, he will wear the same whatever it is on ... do you think I should find a gearbox experienced in software and new type of solenoid ... or is there a master recommendation in Istanbul ..?
Of course we do not know the current software in the vehicle, the new type of solenoids, the old type ... can we find a way to learn this ..? M @ t 2016-06-23 01:28:14
08.05.2020 19:51 # 4
talip206
old solenoids are no longer produced. As far as I know, this issue was also quite an issue for me. Old type solenoids were operating at 50 Hz. Now 100 hz. The connection point of the old type was beige. The present is black. The new solenoid part code is 2574.16. If the resulting solenoid is 100 Hz, there is no need to update. If it is the old type, an update is required. Not everyone can do the update job. Most of them delete the current error and said that I made an update. Your vehicle is probably a new type of solenoid, but I cannot say for sure. I live in Istanbul, but unfortunately I have no idea about the master. The gear position switch does not fail easily, but as you say the master will change, there is one he knows. I think get a price from other places talip206 2016-06-23 01:58:22
08.05.2020 19:51 # 5
Mur@t
Well aspire master; Isn't there any way to find out that it is new and old without removing solenoids? :)
08.05.2020 19:51 # 6
First of all, welcome Murat. the problem is most likely the replacement of the cellonoid valves, as the master and aspiring brother. It will not be obvious when you do not open the gearbox, but any kind of new type of fitting will be installed. you can have the coding done elsewhere. You cut your money from the master.
08.05.2020 19:51 # 7
Mur@t
Thank you....
Let's see yesterday, the master had deleted the mistakes, what will happen when he gives an error again.
Let's say the master couldn't update the software ... would the car walk? Where can I install the software in Istanbul even if it is walking?
08.05.2020 19:51 # 8
talip206
vehicle walking is not a problem, but software is essential for gear changes. In fact, someone who understands can log in from the computer and check how fast the solenoids are. But as I said, you need to find someone who understands. How many models of your vehicle are most likely yours is a new type of solenoid? Authorized services are updating software, but I have no idea about custom.
08.05.2020 19:51 # 9
Mur@t
My vehicle is 2005 model ... I do not know who is in Istanbul who understands the job ... I do not want to have someone from the century ... :(
08.05.2020 19:51 # 10
palet
First of all, I suggest you change the gear position switch and if the fault continues, proceed to other operations.
It is good if you ask the price as Reno scenic AL4 gearbox shift position switch while getting the price for the part. I know that the same piece is sold cheaper than Reno.
palette 2016-06-23 22:57:04
08.05.2020 19:51 # 11
Mur@t
I stopped at the lights on my way to work today in the morning. it was a slightly sweet slope. I think the car driver in front of me was a bit novice, could not get up.
I put the car in reverse gear, it shook down a bit, then I put it back to D position and the gear went wrong again.
I turned the vehicle off and on it improved. then I made 120 kilometers of roads in the city until the evening ...
the error is 80 percent when I change gear position shows that the probability of the position switch is faulty ...
@palette; As you said, I would just change it, but I want it to be made in solenoid and oil change.
Obviously, I couldn't decide what to do. There is a little oil leak in the gearbox, the master said. He said it may have leaked from elsewhere ... if the gearbox is leaking oil, the gearbox should come down ...
M @ t 2016-06-24 00:05:55
08.05.2020 19:51 # 12
Mur@t
There was also a problem that I felt more today ... had done it twice a month before, but today it was 4-5 times while waiting in the lights ...
In the lights, while the gear is in D position, while my foot is waiting in the brake, the car starts to whirring as if it were just singing, or it was just pressing and releasing the brakes quickly ... It takes 2-3 seconds.
I wonder if this is something related to the gear or I couldn't understand my fuel related.
08.05.2020 19:51 # 13
palet
After a few days, you will witness that the gear position shows "N" or "R" while your vehicle is moving forward. You can be sure that the position switch is faulty. However, do not act here with the logic of let's fix all the transmission problems.
1- If your vehicle does not have a knocking / pulsing gear shift that will disturb you (SELENOID REPLACEMENT)
2- If it needs to upgrade but still does not shift gears (OIL COOLER)
do not touch the gearbox.
Your master has already spoken openly about the leakage of oil. As a matter of fact, your master from the color of the oil leak under the engine can easily understand that this is transmission oil or engine oil. However, he wanted to convince you to spend money.
Meanwhile, the master can see if the gearbox oil change is required from the darkening or thinning of the gearbox oil. it is useful to have the oil checked for change.
Good luck with.
palette 2016-06-24 21:16:58
08.05.2020 19:51 # 14
talip206
I think don't get into fat. I was also skeptical, I went to the gearbox master to see if it is leaking oil. Do not be afraid if the oil is gone, he said there would be no oil left. He said that if they leak, their oil is very thin, it will drain them all.
By the way, I don't think that the shaking and flirting thing is about the transmission. He sometimes does it when the air conditioner is on. Was your air conditioner open talip206 2016-06-24 20:44:28
08.05.2020 19:51 # 15
lamazibici06
I advise you to follow the cheapest to the most expensive way in order.
