Pejo 307 automatic mars problem
08.05.2020 20:01 # 1
ndiali
Hello guys, I came to me twice.
1) I went with the vehicle, I got on the evening, I turned on the ignition, the lamps were on, the lights were on, the lights were on, there was no problem, there was no sound, there was no sound, nothing was going to happen, but it did not benefit, although I tried it several times, then I pulled the car with the hammer, I started the car by transferring it to the industry from the master battery, then I went to the battery and then I went to the battery. he said, then I rode for 2.5 months like that, no problem until yesterday
2) yesterday I used the car yesterday I stopped to get the standard gas, I bought the gas, turned the ignition to start the car, the lamps are the lights are on standard again, I did not get starter this time, I have to experience either I wanted to start with a reinforcement from another car, I went to the head of the car today in the morning, I left the car, I bought the car at once. I'm about to eat
The problem I researched in the forum is said to be the engine connection cable with the general starting starter today or tomorrow I will go to the auto electrician and I will rewrite the result here thanks good forums
08.05.2020 20:01 # 2
Get well, as you said, my brother, have the starter motor and its sockets checked.
08.05.2020 20:01 # 3
gergerli
The problem has happened to me many times. I don't know exactly what is the automatic gear starter or sensor under the battery. Even though you run it in P, there is very little water humidity. Take it between the work and do it, when it is installed, it will be fixed, if it is not fixed, that table changes to 150 lira.
08.05.2020 20:01 # 4
ndiali
[QUOTE = gergerli] I have a problem with me over and over again, I don't know exactly what is the automatic gear starter or sensor under the battery, even though there is a little water dampness in P, try to start the car in N or try to start the car in N or the gear. bring your arm between the PN a few times, and when it is set up, it will recover and when it is not leveled, that table changes to 150 lira [/ QUOTE]
you said something very logical because it normally gives the same reaction when you try to run in D
08.05.2020 20:01 # 5
gergerli
[QUOTE = ndiali] [QUOTE = tense] I came to me many times, I don't know exactly what is the automatic gear starter or sensor under the battery, even though I run it in P, there is very little water humidity, and the car thinks in D as soon as the remedy remedies that car N Try to run it or move the gear lever a few times between PN and make it work.
Just like I said, if my brother had other things done and he did not work at P to make big expenses, try N also try a few times, the bottom table got moistened, the problem would be a starter like I said if you hadn't paid money to the hammer.
08.05.2020 20:01 # 6
gergerli
Is it okay bro, have you tried?
08.05.2020 20:01 # 7
Sertan
the same problem happened to me today. My vehicle, which I used yesterday, stayed in the garden of the site this morning. I think it should be made of starter or coal. I hope that N will work, and my first job will be to try.
08.05.2020 20:01 # 8
gergerli
[QUOTE = Sertan] I had the same problem today. My vehicle, which I used yesterday, stayed in the garden of the site this morning. I think it should be made of starter or coal. Hopefully we will work in N sa bah my first job will be to try. [/ QUOTE]
Did it work bro?
08.05.2020 20:01 # 9
ndiali
I couldn't get the electrician because of the work, I came to the electrician right now, I wanted to run again in the morning, the same thing happened to me.
08.05.2020 20:01 # 10
Sertan
no n or d is not working. I called the master room, brother said, you can bring it with the hammer. He did not give up the 20th contact, he took it in my contact. We bought the part price, they said 0 to 500 TL in the industry. It would be around 650 with workmanship. We talked to the master and only replaced the defective parts. I do not remember the coal and its name, we changed another piece and took it to 200 TL. By the way, the interesting thing is that when I went to the master, the master closed the car. Then he ran it again and worked the car. The vehicle turned off a few more times and the vehicle worked every time. I think it's about heating and expansion. The car gets the starter when it gets hot.
08.05.2020 20:01 # 11
I'm glad that the automatic starter problem was solved.
