pejo 307 automatic gear fault error
08.05.2020 19:39 # 1
ndiali
Hello friends 2004 model pejo 307 1.6 petrol lpg I have automatic car solenoids and transmission oil changed in the transmission master but the problem is changed in the vehicle, the vehicle changes to the same error again and protects the vehicle - there is a sign of profit and s there is another solution thanks
Bottom note: Something I noticed gave the fault when opening the boiler right away, I made 20km without opening the boiler right now, it did not cause any malfunction.
the ndial 2016-02-13 17:32:46
08.05.2020 19:39 # 2
burakrak53
Sir, my master said, maybe there is another problem with solenoids. It is also mentioned that if the solenoids are the new type of solenoid corrected in the make-up case, an update should be made in the brain of the vehicle accordingly. I think I think you should introduce the solenoids to the brain, ECU. If you solve the problem, write here. Get well soon
08.05.2020 19:39 # 3
ndiali
Sasmazda aydogmus sanziman, there were those who said that after connecting to the computer, he gave this malfunction, but as I said, he continued to get this error.
08.05.2020 19:39 # 4
burakrak53
Well, there are a lot of people who have written in this forum. The problem is usually solved by solenoid oil change if I showed it somewhere else. Are you getting this error after going a certain distance?
08.05.2020 19:39 # 5
ndiali
Yes, it usually happens after warming up.
08.05.2020 19:39 # 6
ndiali
I realized something very different.
08.05.2020 19:39 # 7
talip206
He may have chased somewhere. He had a subject in the forum for a while. A friend who had dismantled the battery and opened the gearbox's brain underneath and cleaned it with a lining spray spoke about the problem. If you want a famous gearbox solution auto kamil master in Ankara.
And when does the malfunction go, it does it suddenly, or does it stop and take it to n or r, then take it to d and go again
08.05.2020 19:39 # 8
burakrak53
Yes, I had heard of the master, the first good investigation, I think, is to renew the gearbox completely.
08.05.2020 19:39 # 9
ndiali
I will call the Kamil master on Monday, not while stopping or changing gears on the straight road.
08.05.2020 19:39 # 10
ndiali
Especially when going downhill and uphill, it sounds like a plug and then the malfunction code
08.05.2020 19:39 # 11
ndiali
Kamil master made the car with 2850 charges ...
08.05.2020 19:39 # 12
burakrak53
Which parts have changed?
08.05.2020 19:39 # 13
ndiali
1 tk lining 1 tk piston 2 ea band 1 tk bushing 1 ea teflon 1 ea transmission rear seal 2 ea valve 1 ea outlet Convertor 7 liter Oil 1 ea transmission oil filter workmanship 750 total 2650tl
08.05.2020 19:39 # 14
burakrak53
I hope something has changed and I hope it won't be a problem.
08.05.2020 19:39 # 15
ndiali
[QUOTE = burakrak53] I hope a lot has changed, I hope there won't be a problem [/ QUOTE]
today i got the same fault again i will go crazy so much parts changed still the same problem
08.05.2020 19:39 # 16
loyalnovember
The same problem happened to me. In 2004 my 307 vehicle, which I bought in August 2015, a month later s and snow mark appeared. There was a solenoid and oil change at the service. The problem is over 700 TL.
08.05.2020 19:39 # 17
loyalnovember
unfortunately, peugeot automatic gear problems do not end.I have had many problems, big and small. I bought the gasoline needle problem without shaking in the gas.
08.05.2020 19:39 # 18
ndiali
the problem still continues
08.05.2020 19:39 # 19
[QUOTE = ndiali] problem still persists [/ QUOTE]
Is the gearbox checked?
08.05.2020 19:39 # 20
talip206
Hodja, can you check this link
my http://forum.peugeotturkey.com/forum_posts.asp?tıd=40396&kw=&title=automatic-gear-fault-cozu
If you paid so much, took it back to the master, after all, almost everything had to change.
Page : / 2
