Pejo 307 1.4 hdi Fat loss after long road |
| 08.05.2020 17:42 | # 1 |
My car is 1.4 HDI model 307 at 159,000 km. I had 150 thousand servicing. now it has reached 159 thousand. and I have been going on a long journey for two weeks. there is no idling and black smoke up to 2500 rpm. But when I load it to idle gas, it throws black smoke. I made 9000 km. and I looked at the dipstick and the oil fell to the 1st stage. IS THIS NORMAL ? I did not use the vehicle at high speed on the long road. I went between 90 and 110. I have not exceeded 2500 times. I'm waiting for your help.
| 08.05.2020 17:42 | # 2 |
Bugra |
the black smoke job is a bit strange. Now it is important in what situations and how much black smoke is blowing. Even a zero-diesel car today emits black smoke. Diesel is a very normal situation, but you need to know how yours is. 1 stage should not be very important in oil. as a result, the ground of the vehicle at the time of measurement and the time it takes for the oil to fill the crankcase. Don't care 1 step too much. If you care, look at the top cover gasket of the engine, if there is any oil leak.
| 08.05.2020 17:42 | # 3 |
thank you for the answer. There is a lot of black smoke when I load on idle gas. not 1 tier in stages. I saw it fall down to the first level on the dipstick. The man who changed the oil in a petrol on the road, as a leak of oil, said there is sweating.
