pejo 306 wet mat when it rains
08.05.2020 19:36 # 1
CagatayReis
Friends peugeot 306 car only when it rains a lot of wetness occurs on the driver's side under the door mat, a handful of water is formed door wicks have been checked water drain areas are cleaned looked at the door area there is nothing in the honeycomb but for some reason when it rains too much, the bottom of the mat is just getting wet right left pedal part dry middle wetness Is there anything happening to you or having a solution?
08.05.2020 19:36 # 2
CagatayReis
There is no man to answer, so the forum is perfect.
08.05.2020 19:36 # 3
[QUOTE = CagatayReis] There is no man to answer, so the forum is perfect.
Please take care of the words you use. In the forum, information is shared in the framework of love and respect. First of all, you have already checked many of the places to be said, the reasons for such problems are already clear and you know.
08.05.2020 19:36 # 4
talip206
The task of friends who comment here is not to comment on every question here. Everyone has a job, or a school they study, the child they care for, family life, etc. They have something. so nobody has to write. Even when you were writing, you said something like this happened So it hasn't happened to anyone.
who is not a master here. If you say shake on topics you do not know, we shake as much as you want. Besides, call the phone of the master you want randomly in my car, I have the following problems in my car. For example, how do we know that by laying the sound system or doing something extra, where the vehicle was pierced or changed. talip206 2016-01-21 17:44:39
08.05.2020 19:36 # 5
Nezih Ozfirat
I have a similar problem.
They forgot to insert a part during the glass replacement. There is a cover under the left side wiper. The front left damper closes the well behind the cavity, allowing rainwater to pass over this well.
Without this apak, the rain water entering under the left wiper fills into the well I mentioned above. From there it goes down to the pedals.
I would call if I knew the name of the piece.
08.05.2020 19:36 # 6
x571
[QUOTE = Nezih Özfırat] I have a similar problem.
I would call if I knew the name of the piece. [/ QUOTE]
Have you learned the name of that cover?
08.05.2020 19:36 # 7
onlycihan
How many masters did not find that my 206 vehicles came through the doors again I found. I saw the interior insulation material in the speaker replacement, I didn't care if the adhesives were out, but all the water goes in there. Check this by placing the towel or cloth towel in the place where the bottom of the vehicle door presses the wick and close the doors. Check it after the rain, if there is wetness, it is similar to my problem. leaking to the bottom
08.05.2020 19:36 # 8
x571
The hood shock absorbers have a drain hole that was left there, and it was clogged. I found it too. but even before they find it, the glass will change Angry I couldn't believe it, I said.
