pejo 306 overheating
08.05.2020 16:37 # 1
ersin1985
Hello greetings to the doctor. I am writing from İzmir. I bought the model pejo 306 sedan about 2 months ago. Since the day I bought, they could not fix the temperature problem. I had all the maintenance of the car. The last top cover gasket has also changed, but the problem still remains. The chip is removed from the cover, there is no crack or burst. The problem does not rise much when it goes normal with this car, but it goes up to red when it is loaded a little. .
08.05.2020 16:37 # 2
fTh206
I guess the temperature problem of these peugeots is chronic and I can stand up to 100 on my feet but I don't ignore it.
08.05.2020 16:37 # 3
phoenix.1905
Have you filled the cooling system with full water and bleeding? & Nbsp;
08.05.2020 16:37 # 4
ersin1985
Yes, we got the air. There is a screw on the top of the thermostat, we loosen it and get it. We couldn't find the fault.
08.05.2020 16:37 # 5
okankrgz
check the radiator hoses may be clogged ... & nbsp; At the time of
I took my car to the service for this reason, but they could not solve the heat event, the complete water changed air, etc. then i went rad. I said replace the hoses, after the change, there was no temperature :)
Heat the
tool until the fan turns on and off, listen to the hoses, if you hear the sound of squirting, know that the hoses are blocked;) & nbsp;
08.05.2020 16:37 # 6
Fatih Ceyhan
vehicle seal may also be burned, & nbsp;
08.05.2020 16:37 # 7
ersin1985
the gasket has just changed, there is no swelling in the hoses or anything. I don't think of anything else. Finally, I think the indicator may be wrong.
08.05.2020 16:37 # 8
kudret_yildirim
I did not understand what the weather was in the beginning of winter, we opened the cover of the reserve tank and measured the degree of antifreeze. nobody talked about the air or something. there was no problem. Do I need air in me?
08.05.2020 16:37 # 9
djchaos
If the vehicle has made air, it forces the radiator, your radiator may be clogged.
