pejo 306 6500 rpm 7000 rpm help! |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 306 | |
| 08.05.2020 16:27 | # 1 |
volkan22 |
now I am happy with what you need to appreciate to get it out at 6500 electricity 7000 ... < / div> div> |
| 08.05.2020 16:27 | # 2 |
Ucyuzalti |
Something normal electricity cut, it goes all the way if you cancel the breaker & nbsp; |
| 08.05.2020 16:27 | # 3 |
high speed is dangerous for the engine. Both parts are worn quickly and the life of the engine is low. I think it remains original.
| 08.05.2020 16:27 | # 4 |
If you have software, we will help you if you are in Istanbul.
| 08.05.2020 16:27 | # 5 |
KenBlockJR |
You have to cancel the circuit breaker with chip tuning.
| 08.05.2020 16:27 | # 6 |
Ucyuzalti |
What is your fuel, the same fuel as the last truckers |
| 08.05.2020 16:27 | # 7 |
voodoo |
the reason why they put this gas cutter is a research dude ... put it in a bole to stop it, high speed engine everything goes up, fuel increases vibration increases engine pressure rises, warming increases .... I think even 6500 too, I suggest you not to push your luck too hard .. .
| 08.05.2020 16:27 | # 8 |
volkan22 |
walla accidentally cuts the power from the contact, but at least if I increase it at least it would be good in terms of power, I did not shout too much & nbsp; I thought I would get the performance even if the factory setting was low: S made it to our friend tool 2 It has been going up to 7500 rpm for years and you can't believe the power when the car is sitting in series 2, the car flies officially with 2 gears 140: S I'm not going to bomb it from time to time, but I'm going to buck me :) the machine's shoulder will be shortened, but I already see 5 years with this veran, I want to get rid of barley :) & nbsp; my goal is to increase 1000 rpm with chip or add power even if 7000 rpm is not so much |
| 08.05.2020 16:27 | # 9 |
I am converting to 8000 with 206 gti has not been a problem yet.
| 08.05.2020 16:27 | # 10 |
Ucyuzalti |
8000 satin whatever transnational network is possible, you can 10000 10000 |
| 08.05.2020 16:27 | # 11 |
my tachometer is last at 7000 :) translation from 1000 is extra :)
| 08.05.2020 16:27 | # 12 |
must be played with software & nbsp;. If you make software and timing for someone who knows the job, it will not be tasted :) ... it cuts at 7200 in my previous vehicle, it cuts at 8200 in my current vehicle, I had no trouble wandering in the upper ages ... |
| 08.05.2020 16:27 | # 13 |
[QUOTE = okankrgz] needs to be played with software & nbsp; If you make software and timing for someone who knows the job, it will not repeat it :) ... it cuts at 7200 in my previous vehicle, it cuts at 8200 in my current vehicle, I had no trouble wandering in the upper ages ... [/ QUOTE]
