Pejo 206 throat butterfly request
08.05.2020 21:30 # 1
ByOktay
Hello friends
The throat butterfly of my vehicle is broken (idle ripple stop, etc.)
Vehicle 1.4 gasoline lpg none 2008 model sedan
Product information
96 407 962 80
408 239 821 001
EGAST02
Is it a dating or a place we can find? I am waiting for your suggestions.
byoktay 2020-04-23 09:09:50
08.05.2020 21:30 # 2
ismailkaya
I can help if your car's engine type is 1.4 16v 90hp
08.05.2020 21:30 # 3
zerzevat
Are you sure you have a sore butterfly? idling valve .. have you tried the potentiometer?
08.05.2020 21:30 # 4
ByOktay
hello we are sure to have a sore butterfly, we have connected with lounch
Also, as far as I know, the potentiometer is not external inside.
byoktay 2020-04-26 00:18:22
08.05.2020 21:30 # 5
ByOktay
Vehicle 1.4 75 hp throat throttle is not the plastic one.
08.05.2020 21:30 # 6
zerzevat
wired or electronic powered? butterfly.
I suggest you try the valve.
08.05.2020 21:30 # 7
zerzevat
um. this is the electronic one ... since it's 2008 ... yes. I distribute. potentiometer inside ... no valve. you are right.
we are in the same position. sometimes you are looking at our vehicle butterfly is disabled. the gas does not react ... the vehicle goes into protection mode. fan is running on stage 2 ... no heat. from the throat butterfly. I look at the back from the hand, the butterfly wasted ...
08.05.2020 21:30 # 8
ByOktay
Unfortunately, electronic intervention is not intervened, there are not many wires in the market, Kos husband, Ankara, star industry, etc.
08.05.2020 21:30 # 9
zerzevat
Take a look at the accelerator pedal and the butterfly sockets .. after the wasted butterfly do not change.
08.05.2020 21:30 # 10
ByOktay
Thanks, but throat butterfly diagnosis is correct, we have to change
08.05.2020 21:30 # 11
zerzevat
it is not a cheap piece and there are those who do not get results even though they change Make good use of the oxygen sensors and the accelerator pedal. Your last resort is the big butterfly. the choice is yours. respects. greetings.
I wish it would be a medium for a trial .. if folks share their parts with each other.
