Pejo 206's Left Pull
08.05.2020 15:10 # 1
fahrikem
My friends are pulling my car to the left, I have made a rot balance setting in a computer-compliant rot balancing area, the master said that the rot-balance is good, I bought another 4 tires on top of it, but I still have to pull the left, what could be the reason.
08.05.2020 15:10 # 2
what brand of tire ??? I asked him if some low quality tires sometimes get bored ...
Even if the tire has low air, I will say that it will shoot. but I guess it shouldn't have been in the tire, the tire maker had checked as well :))
08.05.2020 15:10 # 3
There may be a reason for the tire pressures on the two sides to differ from each other. It may also be caused by ten brake systems. If so, drive your car for 15-20 minutes and then go down and touch the discs with your hand (be careful not to burn your hand) and try to feel the temperature difference on both sides. The temperature difference, if any, is one of the problem brakes. Koliva 2011-03-17 08:35:33
08.05.2020 15:10 # 4
fahrikem
Tires Lassa miratta pressures are the same
08.05.2020 15:10 # 5
I know you made this mistake on V pattern tires.
08.05.2020 15:10 # 6
[QUOTE = fahrikem] Tires Lassa mirat the pressures are the same [/ QUOTE]
I still recommend you go and check again. He may have missed the eye.
08.05.2020 15:10 # 7
axi206
there may be slack on the rim. I had 1 rim curved (when I was in the past), the bearing was broken. I paid 160 rubles. I got the back wheel hub: @ the lathe handled it.
08.05.2020 15:10 # 8
hasretgonul
I have a similar problem in my vehicle. I couldn't find a solution. I would be very pleased if friends find and write a solution.
08.05.2020 15:10 # 9
dukenukem82
road slope, tire pressure, rim curvature, steering clearance, spring curvature can be anything.
08.05.2020 15:10 # 10
masumserseri
I think it can be from the brakes.
08.05.2020 15:10 # 11
3rkans
There may be a bending in the rim, or the master may not have been able to make full adjustments.
