Pejo 206 Hdi Xline engine fault lamp
08.05.2020 20:20 # 1
bekirozgan
Hi;
I have a 2002 model pejo 206 hdi xline model car. A few months ago, my car started to give a warning sound when I was driving, and I noticed that I felt like this warning sound was given when the vehicle shifted or when the vehicle was forced. Nobody got in the car and connected it directly to the machine and looked like that, and they all said it might be a problem in the engine brain or the installation, but today, I told a master by doing a driving test that the car dropped black smoke and fell out of traction. Although I loaded it, I realized that the turbocharger was activated after 2200 cycles, the master said that there was a problem in the turbocharger hose and turbo airbox of the vehicle and that it was on the engine fault lamp.
Can you help me on the subject.
08.05.2020 20:20 # 2
First of all, welcome to us. What was the error code he gave when they connected the vehicle to the computer, there are many reasons why my teacher blows black smoke, but generally it is caused by the EGR valve. but as the master says, turbo hoses etc. Check. Clean the flow meter.
08.05.2020 20:20 # 3
bekirozgan
Hodja Thank you. They made the connection, but the error code did not come up, one master connected the machine, the engine's brain is not original so we can't see the error code. none of them did not test driving, the third master did a direct driving test and showed black smoke and also said that he missed the turbo because of the hose and the air mass. glass water tank oil maintenance complete replaced all of them. I spent a lot of time, seeing the car falling into the hands of the masters, diesel 1.4 and sometimes when I hit the gas, it seems as if the car is going to speed up, which means that it is slowing down the car.
08.05.2020 20:20 # 4
masters immediately connect everything to the brain, hodja, is the diesel filter originally attached to my side industry? effective reasons in these. the valve may be problematic. it is really hard to find a good master
08.05.2020 20:20 # 5
pusutr
I think it would be more logical to find a solution for such problems in the authorized service.
08.05.2020 20:20 # 6
bekirozgan
Hi;
I took the vehicle to a mechanic today, he gave the error in the screenshot below , but as the previous master said, I looked at the air box coming out of the turbo and the box plays a lot.
08.05.2020 20:20 # 7
bekirozgan
I think there is no one in the friends forum
08.05.2020 20:20 # 8
sdttn
Check brake and clutch sensors are set, they are out of order or cable sockets are problematic or malfunctioning.
You can control it with that diagnostic device, master, there are parts that show whether the brake is applied to the clutch by pressing the icon on the 3rd row.
