Pejo 206 Crankcase gasket
08.05.2020 16:20 # 1
fahrikem
2001 model pejo 206, where I can find the sump gasket, there are varieties of rubber, cork, etc. What is the original pejo 206 gasket.
08.05.2020 16:20 # 2
emin15
You can find out the original net gasket used in the vehicle, give any chassis number to any peugeot service.
08.05.2020 16:20 # 3
Originally, there is another plastic gasket inside the metal gasket. It is available everywhere selling original peugeot parts. I think I once bought it for 3 TL. Say the picture:
08.05.2020 16:20 # 4
[QUOTE = fahrikem] 2001 model pejo 206, where I can find the crankcase gasket there are varieties of rubber, cork, etc. What is the original pejo 206 gasket. QUOTE]
liquid gasket is not used.
08.05.2020 16:20 # 5
fahrikem
Well, is only the above washer gasket going to change? Isn't there any gasket on the face of the crankcase that fits into the crankcase? Thank you whether this washer gasket is placed between the cap and the tank surface of the tightening nuts used in the crankcase tank cap. Thank you.
08.05.2020 16:20 # 6
sahin-peugeot
206 original has no crankcase gasket, liquid gasket is used, if you use a quality gasket, the problem is solved, I recommend you to use victor reinz brand, which will be
black,
