PEJO 206 BACK FROM BACK.
08.05.2020 20:16 # 1
aykutbayram1996
sa friends, when the car enters normal bumps, there is no sound, but there is no information on why it is coming from the back of the road on the stiff roads. There are no new torsions.
08.05.2020 20:16 # 2
talip206
Let me write the things that come to my mind.
1. If the rims are original tin rims, there is a hub, it can play round and sometimes even completely come out and fall into the rim cover.
2. The spare wheel and jack in it can hit each other and make sound.
There is a bolt wrench attachment on the back of the 3rd trunk, if the bolt wrench is removed, it can make a sound.
talip206 2017-03-29 20:09:27
08.05.2020 20:16 # 3
My teacher asked for the situations that our aspiring friend could be and check them already. Thumbs Up
08.05.2020 20:16 # 4
onlycihan
Where exactly is the wheel bolt fitting in the trunk, I did not lift the carpet completely because it was bass when I bought it. the onlycih 2017-03-30 09:42:09
08.05.2020 20:16 # 5
If you lean down where my drawing is, my teacher will have gaps in it
08.05.2020 20:16 # 6
onlycihan
yes i saw the gap there but i never examined it in detail. Is there any clip in it?
And where are you putting the jacks? I couldn't fit it anywhere.
08.05.2020 20:16 # 7
KILIC
No jacks don't get there, just clip for the wheel wrench.
08.05.2020 20:16 # 8
onlycihan
I understand, thank you, the car is not with me, my first job in the evening will be to check it out :)
Well, have you been able to squeeze these suits somewhere or are they standing in the trunk in a bag?
08.05.2020 20:16 # 9
normally my jack is in the step. they must have their own box, they have been dismantled, they may not have been replaced after stepme.
08.05.2020 20:16 # 10
Baran35
I also have bad sounds in the style of plastic parts. If the plastic part of the license plate with lighting lamps has moved from its place, it may hurt, I still haven't had the opportunity to stick it.
08.05.2020 20:16 # 11
KILIC
I think it is inconvenient for the jack to rest inside the spare wheel. I know it happened to me. My car's tire had blown in front of the house. You know, the car collapses because it stands slightly downhill. For this reason, the jack should be kept in the trunk for me :)
08.05.2020 20:16 # 12
aykutbayram1996
I will look at what your friends say. I will take the car to the industry tomorrow.
08.05.2020 20:16 # 13
Baran35
[QUOTE = aykutbayram1996] I will look at what your friends say. I will take the car to the industry tomorrow.
6. They had offered me the Happy Peugeot Citroen service in the industry, but I did not have the opportunity to go, but I did not have big problems to go, but I heard your compliments from several places.
08.05.2020 20:16 # 14
Brcbyrktr
I also prefer iztek as a service .. halil hurts less than ozturke.
08.05.2020 20:16 # 15
Meliksah
Hello friends, where can I get the clip of the place where the pejo 206 wheel bolt is placed.
