Pejo 106 with gas cylinder
20.07.2020 21:23 # 1
Gogo61
Hello friends, I am a new member, I use pejo 106. When my vehicle is warm, the light and oil lamp is on. When the engine is cold, no lamp is lit.When I give the vehicle gas, it goes out. What could be the problem? Can you help me?
21.07.2020 09:11 # 2
First of all, welcome to us. Places to check. 1- When the circulation pump and the timing were last changed 2- Thermostat3-Radiator5-If the vehicle antifreeze was used before, rust oil residues may be clogged in the water channels for the block.4-Oil sensor and oil filter change5- Remove the cartel and clean the inside. 6- Quality brands such as würt have engine cleaners. oil change, you are using one of it before the sump is cleaned, then change the oil and clean the cartel.
