pejo 1.6 110 hp turbos why not malfunctioning
08.05.2020 14:51 # 1
turbo27
friends pejo 1.4 hdi's turbo and 1.6 110 hp engines are quite different as the working principle of the turbocharger. While 1.4s are used in kkk brand german turbo, 1.6 is garret brand turbo is used..kkk and garret are not weighed in both mercedes and bmw like this market. .. as you know, 1.6 hdi's are variable geometry turbo, 1.4 hdi is fixed .... now you must have heard of the variable geometry event .... vgt is named at the bottom vnt at the bottom ... variable geometry turbolar pressure always takes the power of the kernel from the rotation to the last gas. The air in the engine takes the air at the desired pressure ... besides the benefits that the variable geometry pressure adds to the performance, there are also some damages ... remember, no comfort or convenience will be free of charge ... the turbocharged air mechanism that we call vgt will become the biggest disease. ... they will drop at low speeds b The air is closed and the compressed air propeller freeze the heat, it hurts at high speed, the pressure decreases, but the propeller gets less and it does not damage the engine. When these blades lock, you either give low pressure to what you understand, or if high pressure ... high pressure, you can not pass 100 u, because the engine will protect itself from high pressure. If low pressure, the vehicle will stay hard from the ground ... If you connect it, you will understand ... let's use the quality diesel to get to it, because it is not possible to encounter problems in 1.4s, because it is constant, it can be low compared to vgt as performance, but it does not easily fail ... Even when it is dismantled, the rings of the bushings should change, if these operations are done without the turbo failure, the money will not be paid, at least the damage to the engine will be overcome.
