PEGUAT 301 REAR AMARTISOR SOUND PROBLEM
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 17:39 # 1
lusi
friends, I bought the peguat 301 activated model in 2013 model. Since the vehicle has been loaded at 1000 km, it knocks with the 3-4 people in the smallest outcomes when the vehicle is loaded. They said everything is normal. This is the vehicle that was tested for 4 million km. Wow. Cry
08.05.2020 17:39 # 2
What is the peguat?
08.05.2020 17:39 # 3
Zagorka
Peguat? Are They New?
08.05.2020 17:39 # 4
lusi
friends have left the work force ... they are dealing with letters ... if anyone knows about the subject, please answer .....
Also, while I was at school, my Turkish lessons were empty ..... give my ignorance ....
08.05.2020 17:39 # 5
mstf shn
I do not see our friends in the center, our koliva manager has made the beginning, but our regional representative is really nice to deal with the problem. Clap
08.05.2020 17:39 # 6
eray307
Increasing the shock absorbers from 307 to 301 Tongue eray307 2013-06-02 22:34:05
08.05.2020 17:39 # 7
Zagorka
Don't you see me, Mustafa Kardeş, shame on you look now :)
Our aim was not just kidding, it sounded funny, so we don't have any intention :)
I think the problem may be fixed if you change the shock absorber blocks :)
Cente 2013-06-02 22:39:25
08.05.2020 17:39 # 8
mstf shn
[QUOTE = lusi] friends bought the peguat 301 activated model in 2013 model. Since I received the vehicle at 1000 km, it knocks with 3-4 people while the vehicle is loaded. swinging. They said everything I took to the service is normal. This is the vehicle tested for 4 million km. Wow, I was cooled from the car. I am waiting for your help on the subject ...... thanks ..... Cry [/ QUOTE]
hocam the same problem I did not take or something had served me I knew that the outbreak of the shock absorbers bi ara They said that corrupt that the shock absorber when I went to make a preliminary team was saying and fix your situation faken seize very different vehicles than new, but this is turkey everything can be the most correct answers bi other means to ride and test that my mind sooner If there is a difference, then you can say to the expert service officers.
08.05.2020 17:39 # 9
lusi
Thank you for your friends information. I am a new peugeot 301 user. I have not used peugeot before but it has been 1 month since I bought the vehicle. The vehicle has 1200 km in the moment. The back side is knocked even in small pits with the person.Also at high speed, after knocking-out the passes after 100. You try to collect the back of the car. Annoying incident.
08.05.2020 17:39 # 10
Serkan
Hodja 3-4 friends go to a nearby showroom, take a test drive in one of the test vehicles and compare it with your own vehicle.
08.05.2020 17:39 # 11
ogasbes
friends peugot 301 1.6 vti s compatibility problems with lpg
08.05.2020 17:39 # 12
Serkan
[QUOTE = ogasbes] friends peugot 301 1.6 vti s compatibility with lpg is it problematic [/ QUOTE]
A little skill, a bit of a quality kit, a little luck, whether the teacher will cause problems or not, other models using the same engine are also having a lot of problems, and there are also people who ride without years.
08.05.2020 17:39 # 13
ogasbes
zavoolli brc how do their kit peugeot going well
08.05.2020 17:39 # 14
Serkan
Bacanak 1.6 got BRC 2 months ago, no problem for now, if you search for lpg advice in the search section, you can also find the messages of friends using other brands.
08.05.2020 17:39 # 15
Bugra
I guess that the sound of knocking in pits and pits when the vehicle is loaded is from the shock absorber mount. Since the vehicle is new, I will not say that the shock absorbers will explode. so this has no solution.
the skidding of the back is usually at a speed of over 60, and when the light beam is broken and when it enters a small pit, the rear part of the vehicle swings circularly, which means a chronic problem of the 301.
08.05.2020 17:39 # 16
Aziz
[QUOTE = lusi] friends bought the peguat 301 activated model in 2013 model. Since I received the vehicle at 1000 km, it knocks with 3-4 people while the vehicle is loaded.It hits with a sledgehammer from under the ground. They said that everything I took to the service was normal. This is the vehicle that was tested for 4 million km. Wow. Cry [/ QUOTE]
It made the impression that they were deliberate members, there is intense provocation LOL
like sabotage of other brands Tongue
H
the mitşübiş
in toto
Fard
RENO
the waksfog
upel
the Zıbar
intikaaaaaaaamm TongueTongueLOL
08.05.2020 17:39 # 17
mertsari88
My brother also has 1.6 hdi access. At 5000 km, I'm driving now. Shock absorbers are a little stiff. Likewise, I went to the service and showed it. Unfortunately, there is nothing to do with these tools.
But I disagree with you on skidding. I think the vehicle is very safe in its class. I suggest you get on a new clio and do a test. You will see the difference very quickly;)
[QUOTE = lusi] thank you for your friends info. I am a new peugeot 301 user. I have not used peugeot before but it has been 1 month since I received the vehicle. The vehicle now has 1200 km of this problem. With the 3-4 people, the car knocks the backside even in small pits.Also, at high speed, after 100 passes, it knocks and oscillates. You try to collect the back of the car. I would be glad if you show ... [/ QUOTE]
08.05.2020 17:39 # 18
Mustafa-almanya
It's a pity. All new cars, a lot of problems. The problem is resolved in the thesis time.
08.05.2020 17:39 # 19
msk_sansal
[QUOTE = Aziz] [QUOTE = lusi] friends bought the peguat 301 activated model in the 2013 model. Since the vehicle was loaded at 1000 km, it has been hit with 3-4 people with the sledgehammer when the vehicle is loaded. After that, the back of the vehicle is oscillating in the pits. They said everything I took to the service is normal. This is the vehicle tested for 4 million km.I'm wow. Cry [/ QUOTE]
H
the mitşübiş
in toto
Fard
RENO
the waksfog
upel
the Zıbar
only the names you joke with your brands, heki japanese origins take the first place in the list of vehicles without problems.
folks say I'll buy french and get irritated and get japanese.
but in my heart it is 307 hdi `m number 1 :)
