Pego 206 X line eco mod problem
08.05.2020 21:24 # 1
Yasam79
My car has not been running since it entered eco mode. You called the master, there is no problem, but the vehicle does not leave the eco mode. Is there anyone to help? Yasam79 2019-12-18 20:58:27
08.05.2020 21:24 # 2
omerb
hello, did you try to run with the jump lead
08.05.2020 21:24 # 3
Yasam79
yes i tried it didn't work again. Believe me, there is nothing we haven't tried, but as soon as I turn the ignition, eco mode text appears.
08.05.2020 21:24 # 4
omerb
Do you have a spare key. I try with it, I think
08.05.2020 21:24 # 5
Yasam79
I don't have a backup key, do you think it will be useful if I come out new. Someone else said the same thing to me today. Mars is pressing but still experience is a backup.
08.05.2020 21:24 # 6
omerb
they say
If there is a bad battery, the vehicle forgets the key code. The way to understand this is to open the driver's door with the key inserted in the ignition switch. If the vehicle warns beep, it means it recognizes the key. If it does not warn, it does not recognize the key.
Another place is to try to run the vehicle by pulling a cable from the positive box of the battery to the starter dynamo with a thick cable. I think ecu considers the vehicle's battery weak and does not exit eco mode. But if you feed the starter motor, they said the car gets a starter.
08.05.2020 21:24 # 7
Yasam79
My first job tomorrow will be to try them. Thank you so much. I hope it works.
08.05.2020 21:24 # 8
omerb
Please watch the video in the link. First, make sure the key. Last chance you check it, master. Just watch out for the battery terminals.
08.05.2020 21:24 # 9
Yasam79
thank you so much again
08.05.2020 21:24 # 10
Yasam79
There was a problem in the brain of the vehicle. I took it to the brain, loaded a program and the vehicle is running now.
08.05.2020 21:24 # 11
get past it. thanks for the return
08.05.2020 21:24 # 12
ismailkaya
Could the alternator be faulty?
08.05.2020 21:24 # 13
Pejoant
The problem is solved. Thanks for information.
08.05.2020 21:24 # 14
Yasam79
Thank you very much.
08.05.2020 21:24 # 15
Yasam79
Can [QUOTE = ismailkaya] alternator malfunction? [/ QUOTE]
There was a problem in the brain. Eco did not exit mode. The problem was solved when the program was installed.
