Pego 206 throat butterfly
08.05.2020 21:28 # 1
Yasam79
When I have the friend car connected to the computer. There is an article called throttle / pedal position sensor / A switch circuit low input. Can I have it repaired or should I buy a new butterfly?
08.05.2020 21:28 # 2
MDKBKR
Are you getting the malfunction code P0121? I have repeatedly received this fault code in my vehicle. My vehicle is 2007 model 1.4 8v 206. Although I can't solve this problem 100%, I haven't been getting error code for a while. Do not touch the evil eye :-)
08.05.2020 21:28 # 3
Yasam79
yes i get the same error code. I'm researching if the problem is solved if I just replace the Nette sensor. Could you solve the problem?
08.05.2020 21:28 # 4
MDKBKR
That sensor is embedded in the throttle. It is not possible to just replace the sensor. Is the position sensor separate in your vehicle? Simply say, have the socket and the cables checked. Sometimes it can be solved in a simple way. The same error may also point to the sensor on the accelerator pedal. The electronic accelerator pedal also has A and B sensors. Check the socket and wiring of your accelerator. P0121 error was also on my vehicle. I bought ELM 327 for 12 lira just because I wouldn't give 30-40 lira to erase the errors :-) It saved me many times. I haven't been getting an error for a long time. When I last checked the socket of the gas pedal, I saw it was loose. I put it in place. I did not change the masters who said the throttle will change :-). Let's see what time will show.
08.05.2020 21:28 # 5
Yasam79
Thank you very much, my first job tomorrow will be to try them.
