pegeout 307 1.4 hdı xr diesel problem
08.05.2020 20:09 # 1
uguur
good forums, first of all, my friends bought pegeout 307 1.4 hdı xr diesel vehicle about 7 months ago 210000 thousand was the problem that was first evident in my vehicle 229000 thousand and the problem I did not solve is not solved, although I do not show it to many masters.
the vehicle engine warning light is on and the vehicle stops, this process is done 3 times 4 times a day according to the usage period, only in the 4th and 5th gears, i.e. when I go over 90 km speed, the vehicle stops with the engine warning light at low speed, sometimes it stops at idle. to be short in general
no problem at the first start of the vehicle, when I slow down in motion, the engine warning light stops flashing, does not eat gas, then I changed it from diesel filter to pollen filters 3 times, connected to the computer, problems were detected, necessary operations were carried out, but the same problems continued to occur each time again the next day.
only the remaining turbo solenoid valve and the electrical parts of the vehicle remained in the engine . you know if this style of problem is alive? Lamp
08.05.2020 20:09 # 2
In addition to the tubo and cellophane, the air flow meter should be checked. so do you remember what my teacher gave me the fault codes? Well, did you ever get an oil pressure error? injectors etc. I was checked. These types of problems are often encountered in diesel vehicles due to the use of very short distances for a long time.
08.05.2020 20:09 # 3
By the way, my teacher deleted the other topic, this has been moved under the title you should have opened. good forums.
08.05.2020 20:09 # 4
uguur
yes many error code output pressure error code emission drop error code gas pressure emission + gas pump code minimum level error codes there were a few more like fuel pump then I can't remember exactly these errors were corrected but after 2 it started to give again
