Pegeout 206 Idle Stops In The Morning
08.05.2020 15:01 # 1
utopiast
Hello Friends I have a pegeout 206 xt 1.6 2000 model vehicle, I bought a new vehicle alone for 1-2 months. When my vehicle is cold in the morning, the idling stops by falling. As soon as you take your foot from the gas, the idle falls and stops directly. When I bought my vehicle, I had zero BRC brand lpg. But there is absolutely no problem in switching to the tube, but when I run it in the morning, it always stops. what could be the problem
08.05.2020 15:01 # 2
dukenukem82
the throat butterfly will change, this problem was also in the old owner of the car, try to change the throat butterfly, and there is a section where the new members will introduce themselves.
08.05.2020 15:01 # 3
The vehicle must first be connected to the computer and checked thoroughly. But I think the throttle doesn't easily break down. First of all, I expect the above sensors to fail. such as throttle position sensor, outside air sensor, butterfly heater, idle valve etc ...
Do you do it again when the engine is hot? or just doing it when it's cold?
08.05.2020 15:01 # 4
eneslan
there is an electronic part that provides the idling, maybe because of it.
08.05.2020 15:01 # 5
reserpin
Let's introduce ourselves first
08.05.2020 15:01 # 6
AliOzagan
I have the same problem, I did not find the reason why I did not gas at idle when the 2001 petrol automatic gear was running in the morning and it shuddered and stopped directly when I took the gear d or 3e: ((((((
08.05.2020 15:01 # 7
kasirga85
friends, we have a different problem in our partner, when it first runs idle speed is 1000 cycles then it goes over 1000, can cause
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
