Pay Attention to Your Air Filter ...
08.05.2020 15:46 # 1
Today, the most important reason of the abrasions occurring in the engines is the dust in the air absorbed from the air filter. maintenance or improper maintenance to the air filters cause extremely expensive failures in the engine (abnormal abrasions in the cylinders, pistons, bearings, crankshaft, valves, cylinder heads) Especially frequent cleaning of dry air filter elements, other than the recommended cleaning methods, cleaning process. Doing (cleaning by flapping, hitting the filter element or small punctures, ruptures occurring when the element is disassembled, disassembled, tearing) may cause the holes of the micron level of the special material to grow and excessive dust to the engine. they do great damage to the engine instead of benefit.
Dry air filters;
. & nbsp; & nbsp; Do not clean the filter element without the dry air filter warning light on the instrument panel.
. & Nbsp; & nbsp; Replace clogged filter elements with new ones, if any.
. & Nbsp; & nbsp; The clogged filter element should be cleaned with a maximum of 6 psi compressed air and by blowing air into the inside of the element. The air gun or air hose tip should be at least 3 cm from the filter paper. The air gun tip or the hose tip should not be in direct contact with the filter paper, or cleaning should never be done by hitting
. & Nbsp; & nbsp; The outer filter element can be cleaned up to 6 times.
. & Nbsp; & nbsp; When the outer filter element is changed 3 times, the inner filter element must be replaced 1 time.
. & Nbsp; & nbsp; Check whether the filter drain valve is clogged during daily maintenance.
08.05.2020 15:46 # 2
pug 307
thanks for the important bi & nbsp; topic sharing
08.05.2020 15:46 # 3
nice sharing & nbsp;
08.05.2020 15:46 # 4
important information, health to labor.
08.05.2020 15:46 # 5
Haksen016
thanks for sharing.
08.05.2020 15:46 # 6
It was one of the issues that we would pay attention to ... I hope it will be useful to our site ..
08.05.2020 15:46 # 7
denominator sharing thank bro "Thumbs
08.05.2020 15:46 # 8
[QUOTE = OsmaNDogaN] denominator sharing bro thank you "Thumbs [/ QUOTE]
< br>
08.05.2020 15:46 # 9
dinoco
and most importantly, we should always use the original filter. air permeability is not the same in all brands of filters.
is very important. It provides the most ideal air permeability in the original filter.
08.05.2020 15:46 # 10
thanks for sharing
08.05.2020 15:46 # 11
metin
bro, good health to your hands,
& nbsp;
you don't look for my colonel, maallah,
08.05.2020 15:46 # 12
cuneytatay
thanks for sharing
08.05.2020 15:46 # 13
artes34
Ersin, you provided useful information, thanks to your health.
08.05.2020 15:46 # 14
Thanks for useful information. Let me ask what's on my mind. What do you call internal filter and external filter? I know that there is an air filter in my vehicle. I know it's wrong?
