Pay Attention To Get Adequate Efficiency From The Car !!
08.05.2020 13:59 # 1
If there is a decrease in engine traction, if the exhaust gas is black and the engine is running hard, it means that your vehicle is spending above normal fuel. Each simple measure will save 10 or even 20 percent fuel.
WRONG USE EXPENSES MORE GASOLINE.
· Make the gear changes according to the engine speed, the appropriate engine speed range for changing gears is 3 thousand - 3 thousand 500 in gasoline cars, 2 thousand - 2 thousand 500 in diesel cars. Changing gears at higher revs increases fuel consumption.
· Do not increase the gear when the speed is low. Increasing the speed at the same rate when you increase the gear increases fuel consumption.
· Do not shift the gear into neutral when descending. Contrary to popular belief, this does not eliminate fuel consumption. When the gear is neutral, the engine runs at idle and consumes fuel accordingly.
Do not use the air conditioner too often. It increases fuel consumption.
· Do not follow the vehicle in front too closely. Because you press brake or gas all the time. This causes additional gasoline pumping. Pressing the gas after a sudden braking increases fuel consumption by 5 percent.
· Go 80-90 kilometers on an intercity road. Each kilometer over 90 kilometers means a 1 percent increase in fuel consumption.
· The speed of the vehicle must not be less than 25 kilometers. Less than 25 kilometers causes the vehicle to consume excess fuel.
Do not wait for it to warm up after starting the engine. The engine will get warm on the road. It means time and excess fuel lost.
When you move with a cold engine, shift to second gear immediately.
Cover the radiator front with newsprint paper so that your engine does not cool down too much in winter. Fuel consumption is high in cold engine.
· Do not open the windows while your vehicle is in motion. Opening the windows leads to increased wind resistance and thus fuel consumption.
DO NOT neglect CARE
· Have your engine's adjustment and maintenance done by qualified people. If your engine is overheating, take your precautions, otherwise your fuel consumption will increase.
Pay attention to the cleanliness of the Havsa filter. Clogged air filter increases fuel consumption.
Install the air filter according to summer or winter conditions.
· Make the distributor platinum setting according to the catalog values.
Check the battery connecting rods. Disorder lowers engine efficiency.
Be careful that the spark plugs are not adjusted and faulty. Uncontrolled spark plug increases fuel consumption by 10 percent.
Make sure the idling speed is at the catalog value of 9. High speed increases fuel consumption.
Straighten the tight and sticky gas pedal.
· Have brake pads checked frequently. If it is unregulated and tight, wheel rotation is forced and fuel consumption increases.
If your clutch scrolls, have it adjusted. Shifting increases fuel consumption.
Have the front layout setting checked every 10 thousand kilometers.
Use tire air at the appropriate pressure, low pressure tire increases consumption by 10% due to excessive friction.
ERROR FILLING OF THE TANK INCREASES CONSUMPTION.
Fill your tank with the slow speed of the pump.
· Do not fill your tank to the brim. Otherwise, gasoline vapor will exert pressure on the tank cap.
Always keep the tank full, because evaporation is greater with less gas.
In diesel engine vehicles, fill the tank with quality diesel after the daily work is finished.
· When buying gasoline, make sure that the money part of the pump is reset.
· Make sure that the gas tank cap of your vehicle does not leak fuel.
is an excerpt ..
08.05.2020 13:59 # 2
sinan-s
Nice share ..
08.05.2020 13:59 # 3
thanks for sharing emrah Wink
08.05.2020 13:59 # 4
DO NOT neglect CARE Thumbs% 20up
08.05.2020 13:59 # 5
gokhansari_1
thanks for sharing the necessary information
08.05.2020 13:59 # 6
In addition, be careful not to stack the vehicle. Compressor braking down the gear that we brake can sometimes cause unimaginable results.
