Passenger airbag cover
08.05.2020 16:54 # 1
safrane23
Greetings. Guys, the passenger airbag cover has to crack the cover, the old owner has put the knee there, and now the airbag is cracked from the full blast points.
08.05.2020 16:54 # 2
As far as I know it has no screws. You will either replace the breastplate completely or it will be bonded, covered etc. with good workmanship.
08.05.2020 16:54 # 3
metin
Most 206 also have this problem. The passenger knees the knee to the torpedo, and that part cracks right away, as the airbag is a bit weak to open comfortably. Not only the cover is sold. & Nbsp;
Also, if you stick it from the inside, if the airbag is not broken, it may not open or tear, etc. Because it is possible that the same thing happens when you change it.
08.05.2020 16:54 # 4
spearo
It is sold as a single cover. It has a price of 140 TL.
08.05.2020 16:54 # 5
safrane23
Hepsipejo is available on the cover but how do I get the original so that I can put the new one ???
08.05.2020 16:54 # 6
nkre51
open the glove cover, you will see two screws above
when you unscrew the two screws, you will unscrew the inside of the glove cover
and you will encounter two more screws above
you cannot change the cover without removing the complete airbag
< div> airbagin cable passes behind the tape & nbsp; you need to unplug it on the tape
