Partner working problem
08.05.2020 17:12 # 1
mlvnt
When I turn the ignition to start the car for 2 days, it doesn't work as if there is no electricity (battery is new) ...
then when I try again and again several times, it feels like it is not diesel, then it shakes the engine vigorously and shake it. & nbsp;
I have encountered such a situation. ...
Regards ....
08.05.2020 17:12 # 2
MagicPerformance
There is a problem with the glow plug or the diesel filter (with the air intake), if the problem continues, the valves may have connected the institution.
08.05.2020 17:12 # 3
baha1907
The same problem happened in my car last year. In those cold times ... & nbsp;
I changed the battery and the problem continued. 150 TL
then I went to the service and they said that 4 spark plugs had exploded. We changed 100 TL
we changed the spark plugs, so the problem is solved.
08.05.2020 17:12 # 4
ahmet_bjk
First of all, you say that there is no electricity, then you say that I started again and again !!
If the battery is discharged, you can never start, even if the battery is completely discharged, you can not even start the car by hitting the car. As friends mentioned above;
& nbsp;
1) Diesel filter may be clogged. If you replace the filter, it will recover.
2) The spark plugs may be defective.
08.05.2020 17:12 # 5
baha1907
[QUOTE = ahmet_bjk]
First of all, you say there is no electricity, then you start again and again I start !!
If the battery is discharged, you can not even start a starter, even if the battery is completely discharged, you can not even start the car by hitting the car. You have to wire a cable from another vehicle. As friends mentioned above;
I think the 4 spark plugs exploded and there was a problem in the brain. But the fixtures were new, I was constantly getting the diesel from the shell
08.05.2020 17:12 # 6
ondercan
Have the spark plugs checked.What does it do when I run it again, what does it do normally? What is the engine power of the vehicle? 2000 engine.
If 2000 is a motor, compressor measurement may be needed. I came across a few problems like this. I suggest you show it to a good master.
08.05.2020 17:12 # 7
baha1907
[QUOTE = ondercan]
Have the spark plugs checked. So what does it do when it is running again? What is the engine power of the vehicle? 2000 engine. > But of course, we are just exchanging ideas by writing here. I recommend you to show a good master. Yes, 2000 hdi engines. What is this compressor, who benefits this measure?
08.05.2020 17:12 # 8
ondercan
ENGINE COMPRESSION: The pressure created by the gas taken into the cylinder at the time of absorption in the combustion chamber at the end of the compression time is called compression or compression pressure (engine compression). The combustion pressure is approximately four times the compression pressure. Therefore, it is obvious to what extent the compression pressure affects the end-combustion pressure. The high compression pressure ensures that the end-combustion pressure is high. The high combustion pressure means that the pistons move with greater
force and the engine is stronger.
The lower compression pressure leads to lower combustion pressure. When the end of the combustion pressure is low, since the pistons will move with smaller force, it causes the engine power to decrease and fuel consumption increases. .
not.alşııdr man explained very well
08.05.2020 17:12 # 9
baha1907
[QUOTE = ondercan] MOTOR COMPRESSION: The pressure created by the gas taken into the cylinder at the time of absorption in the combustion chamber at the end of the compression time is called compression or compression pressure (engine compression). The combustion pressure is approximately four times the compression pressure. Therefore, it is obvious to what extent the compression pressure affects the end-combustion pressure. The high compression pressure ensures that the end-combustion pressure is high. The high combustion pressure means that the pistons move with greater
The lower compression pressure leads to lower combustion pressure. When the end of the combustion pressure is low, the pistons will move with smaller force and cause the engine power to decrease and fuel consumption to increase. .
note. the quote has been explained very well [/ QUOTE]
thanks beautiful quote. but when idling, it doesn't seem to carry a heavy load. it is quite comfortable at idle.
