PARTNER WITHOUT STOP ??
08.05.2020 14:13 # 1
TheEchoes
I don't know if any of you have happened Sırıtma When the switch of the interior lighting lamp of the 1999 model partner is in the closed stage or the constant burning stage, there is no problem, but when I bring the door to the stage that should be lit when it hurts (the doors are not lit even if it hurts, the room is separate), the car continues to work even if I turn off the ignition and remove the key. Sırıtma but when you turn the knob to its off level, the engine stops.
08.05.2020 14:13 # 2
osterreich
If you took the vehicle 2, maybe the previous owner of you made a secret contact? : p
08.05.2020 14:13 # 3
FIRAT.75
A tragicomic event would be the most "logical" that the above friend said. EmbarrassedKahkaha
08.05.2020 14:13 # 4
arifkemal
the important thing is how it works when running, is there any oddness when running it?
08.05.2020 14:13 # 5
CIHANGIR_DONMEZ
THE IC LIGHTING CENTER IS A CURRENT CASE CONNECTED TO THE LOCKING SYSTEM. IMMOBILIZER MAY HAVE A POSSIBLE STATUS IN THE VEHICLE.
08.05.2020 14:13 # 6
TheEchoes
I just bought the vehicle, but I don't think it's immobilizer. there is no central lock on the doors Gülme But when I run a caregiver what Arifkemal says, I don't know how it will be. Kahkaha
08.05.2020 14:13 # 7
peugeotefe
They tried to cancel immo they couldn't do it, the customer on the diesel pump should change
08.05.2020 14:13 # 8
TheEchoes
It started to hang on the car head thoroughly. There is no problem with the starter. If the lamp does not affect the starter, sometimes it blows on the head, it may not go out when the doors are bitter. or sometimes it doesn't cause a problem in stop taste. it is not clear what to do when. I only realized the presentation, while I stopped the car while the light was on (doors open position), the battery light on the table continues to light up very lightly. pugeotefe my master, this change of sender radically solves the problem of solving the problem and how much room is of course important.
theechoes 2010-04-12 01:34:51
08.05.2020 14:13 # 9
TheEchoes
When the masters take a starter, a lamp similar to the letter f stays on for 3-5 seconds. I didn't know what it was. Does anyone have information?
08.05.2020 14:13 # 10
hasimayaz
They tried to cancel immo .. bsi and its installation needs to be thoroughly reviewed.
08.05.2020 14:13 # 11
TheEchoes
Does my master cost much?
08.05.2020 14:13 # 12
Eyup Duygun
Acarda can not open the installation is already a full cost of nothing else, nothing else, but there is a repair, there is output vsvs tickles ...
08.05.2020 14:13 # 13
TheEchoes
it goes where it goes or not, it matters Dil Çıkarma
