Partner Tepee Cruise Control Problem
08.05.2020 18:11 # 1
muratozgur
Hello, I just joined you
1.- Your name and surname: ------------------- Murat ÖZGÜR
2.- Your age: ------------------------------- 28
3.- Your Vehicle (Brand, Model): -------- 2013 Partner Tepee Active 1.6 HDİ 92 White (Alp)
4.- Your Hobbies: --------------------------- Researching on the Internet, Listening to Music
5.- Your profession: --------------------------- Electricity - Electronics
6.- Where did you hear the site: -------- Google
7.- Your Blood Group: ---------------------- 0Rh +
8.- Your Sign: ---------------------------- Sagittarius
9.- The team you support: ------- I do not hire a team
10.- Which county or province are you in: -------- Konya / Meram
11.- Your MSN address: --------------------- murat_ozgur@msn.com
I have a question that says I bought Partner Tepee, the new Euro5 engine, in December 2013
Before that, I had a 2004 Partner 2.0 Hdi, I used the Speed Stabilization System after that. In 2009, I actively used my vehicle while selling my vehicle, I disassembled the arm, to install it in the new car I bought, but in the new models that the service says, it is not possible to open this feature from PP2000. Is there ?
08.05.2020 18:11 # 2
ahmet_bjk
First of all Welcome ...
the service is already retrofitted against speed stabilization.
When I plug it into 308, we tried pp2000 but we couldn't find the menu, then we activated it with the DiagBox program from the forum.
If you go to a master with a DiagBox program and a vehicle connecting cable, you can activate it.
If you cannot find someone with the DiagBox program, you can download it from the internet and install it with the connection cable.
ahmet_bjk 2014-01-09 22:09:46
08.05.2020 18:11 # 3
muratozgur
@ahmet_bjk
Thank you normally, there is a menu in pp2000 but when it is activated it seems like it is blocked
08.05.2020 18:11 # 4
ahmet_bjk
what error does it give?
08.05.2020 18:11 # 5
muratozgur
Security error does not acknowledge
If I have time tomorrow, there is another service and I will hug him
but if it doesn't work it'll be a big disappointment to me cause I'm so used to it
08.05.2020 18:11 # 6
ahmet_bjk
If you turn the limitation on error, a part that should be at the end of the accelerator pedal may not be in your vehicle, just open the fix and try.
08.05.2020 18:11 # 7
muratozgur
There is no limitation on the arm we wear, I only have the fixing version, but it may have gone wrong with something, but before I bought this car, I went to citroen and they said that we could not install it on euro5 models.
08.05.2020 18:11 # 8
ahmet_bjk
The service does not plug in anyway.
I don't think there is an obstruction to Euro5 engines because cruise control is not about the engine, it's about the brain.
If you do some research on the forum, you can find more detailed information on this topic.
08.05.2020 18:11 # 9
muratozgur
@ahmet_bjk
Thank you for your interest
08.05.2020 18:11 # 10
Alicilik
You have to activate it from Diagbox. Diagbox is more efficient in vehicles after 2006. I can help you if you arrive in Ankara
08.05.2020 18:11 # 11
muratozgur
@ Alliance
Hello, I come to Ankara once in a while, if I cannot do this in Konya, I will come to you when I come to Ankara.
Thank you
08.05.2020 18:11 # 12
Alicilik
[QUOTE = muratozgur] @ Alicism
Thank you
I always wait.
