Partner Tepee Blue HDI (2018) Making Front Chest Sound
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
08.05.2020 21:22 # 1
cantayyip
On January 2, 2019, I bought Partner Tepee 1.6 Blue HDI Allure 120 "0" Zero vehicle from Kahramanmaraş Peugeot dealer. 2 years warranty.
From the first week of my car , the " Middle Part of the Front Chest" began to sound. Especially where the windshield and the chest meet. I said I'll be a little patient. I took it to the dealer service that I bought after 40 days. I bought the car, at first there was no sound, the same sounds a few days later. They made liquid silicone. Then I went once more. My teacher, you are very sensitive, this is the first time we have encountered such a thing, they said. This time, areas supported by double-sided sponges. Sound again, sound again. All my enthusiasm has escaped. I went again for the 3rd time in Vesselam. And then the same. It is certain that the Service cannot or does not want to solve this work, even though we have been doing test drives for miles each time. What kind of sanction can I apply? ... We have the power to work, being annoyed with unrelated service workers makes me angry.
My question is;
This sound is continuous and violent when driving at low revs, on keystones or on low-gear or problem roads, descending with downhill engine braking. It's like a severe SHRINK between glass and plastic. As if plastic lopur lopur is shaking, there is a sound. Also, after driving for 20 minutes on the long road, the sound is continuous. WHAT CAN I DO? What's the solution?
08.05.2020 21:22 # 2
omerb
Hello Tayyip, good luck. There are problems with new vehicles. I know this best.
I also have a 2018 ford courier. I got zero. I have voices coming from doors, chest, etc.
I told the service at the first maintenance. I encountered the same treatment as you. Courier's trim sounds are always the subject of complaints. He knows this very well in the service. Although the service master hears the sound, he calls me normal. What will you say to this man? My suggestion to you is this. You will unmute the tape less. You won't be stuck in the sound. If the vehicle doesn't have engine etc problem, go ahead brother. Do not get your chest removed and do something. You will encounter more extreme voice. There were those who made Courier people. They are disgraced. They came to the degree of burning their cars
But if you don't want to hear sound, let a friend drive the car on a bad road. Pinch something between the glass and the chest. If the sound is squeaking, find the creaking place, whisper lightly with graphite spray oil or wd40. The rubbing sound of the metal to the plastic or the rubbing sound of the glass to the plastic gives a squeaking sound. I'm turning on the music, brother. I continue. The fact that the vehicle is guaranteed does not mean that you will deal with every problem. This is my experience so far. All the tools I bought are zero. And they all have problems that I couldn't handle. When the guys say this is normal, the job is already over.
If you say that I will deal with the province, I know that if the vehicle is registered on the person, you are applying to the consumer arbitration committee and if it is registered on the company, you are applying to the commercial court. The court etc also takes quite a long time. I was able to return a shoe in 1 year. You calculate here.
08.05.2020 21:22 # 3
cantayyip
Omer Bey, thank you for your interest. You are right in what you say. That's why I changed two vehicles that I couldn't analyze. However, they were second hand. We got zero in order not to have this kind of problem and to use it widely! the result is usually as you say.
After this, I was looking at Ford Courier 2019. What would be your advice. Would there be a closed panel or another vehicle that I could use? Thank you from now. Good night
08.05.2020 21:22 # 4
omerb
Mr. Tayyip, do not mind the 2019 courier. My vehicle is the newest make up case, so the same vehicle you will buy in 2019 is the same as my vehicle, only the production year is different.
There are such problems with this vehicle that you will search for your current vehicle with a candle.
Is Şikayetvar. If you look at Com, you'll see. Vehicles constantly give engine and oil warning.
There is something called dpf in diesels. For the first time I felt this feature in ford. If you drive on normal road with the vehicle, dpf is activated, the performance of the vehicle decreases by 20%. Especially if you stop and get up while he is on. When it emits gas, it stacks back, and when it pulls its foot from the gas, it stacks forward. It's like you're in a 70 car. When I take it for this problem, they say normal and get out of the business. Have as much guarantee as you want, brother. Even if the master said normal, even the general manager of ford doesn't look back at your vehicle. They put a tire pressure warning system on the vehicle. It warns when the tire comes down. You get the tire but it doesn't reset. There is a mode in the menu called reset tire pressures. But he wasn't working. There was a software error. So what are you saying? When you get this warning, you will come to the service, they say we are zero. You know, courier, never. You will be very regretful. I do not use commercials due to my job. But my commercial love is over. I will buy 2018-2019 peugeot 3008. The wide car is comfortable, its interior and exterior stance are very attractive. Luggage loading area, without threshold. So it's flat. He will see my work too much. I hope I will get it in January 2020. I looked at user complaints, there are only problems with adblue. No other bad comments. There are also some dealers who have dealer problems. These complaints are important.
As a result, I suggest you stay away from courier. I also bought the 2015 model as zero. It was relatively smooth. I made an order before the 2018 make-up case was released. I waited 1 month. But come see that Turkish engineers have finished all the quality of the ford. It is very painful to say this, but it is true.
08.05.2020 21:23 # 5
First of all, welcome to us. Unfortunately, if you say why it sounds like they are sending the troubled ones to our country for some reason in the zero vehicles that our friend says, we have no sanction for these companies, unfortunately, they do not stand behind their consumers like Europe. unfortunately, they hang out in shake-and-go mode just as the companies do for you. In addition, this type of trim problems appear much more frequently in vehicles that are commercially available. For example, passats can appear in many brands such as trim sound coming from the display. A little bit of luck. If you live in Europe, make sure that the firm would find a definitive solution. Now, production of partners has stopped, instead of rifter, and I say test drive with it.
Like sample news, hodja.
this incident never goes to court, even in europe.
If you read here, it's not just in the wv gene. so many brands
sonerkyl 2019-11-28 16:33:29
08.05.2020 21:23 # 6
cantayyip
My Dear Friend Ömer and Moderator Soner Bey, thank you very much for your advice. It was very useful for me. I think I will use my partner tepee vehicle for a while. I will try to identify the places that sound. << maybe I'll take it to the service in Gaziantep. Gaziantep shopkeepers are a little more concerned. Hope it is resolved.
I greet you.
08.05.2020 21:23 # 7
You are welcome, please talk to the other services you call my teacher, maybe they produce solutions. If necessary, contact France and sometimes the source of such problems is solved, but our authorized services may not find the source of the problem because they do not check in the system.
08.05.2020 21:23 # 8
omerb
Hello Tayyip,
You may have a service shortage in Kahramanmaraş.
As Soner said, there are not many masters reading the updates. When I look at the complaint, peugeot pays great attention to customer satisfaction.
I have never seen such a situation in any brand. If you haven't done so, try calling customer service. But I think getting service from the same service. If possible, it could be Gaziantep. (my hometown)
You can ask customer service to call you and make an appointment for a reliable dealer there.
Maybe it can be effective. Don't forget to eat chickpea wrap while you're gone :)
