Partner Tepee 2016 5th gear shaking
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
25.10.2024 21:00 # 1
ahmetfazil
Partner Tepee 2016 Vibration in 5th Gear. The vibration only occurs in 5th gear under load, but it doesn't occur when the throttle is lifted off. The vibration increases with acceleration. The transmission was opened, and the 5th gear bearing was replaced, but this didn't fix the problem. There's no problem with the transmission gears. A mechanic said this model is chronic, but I couldn't find a specific problem online. Has anyone experienced the same issue and found a solution?
22.12.2024 16:41 # 2
ulas55
Hi brother, I have the same car, a 2017 model, released in 2018. I couldn't find a solution to the transmission problems of this car. I've been using it since 2020. I bought it second hand. When I bought it, it had only 20,000 km on it. There is a strange transmission humming sound since the day I bought it. The transmission was disassembled twice and the bearings were changed. My humming sound persisted, but it's not like what you described. My problem is this: it doesn't matter whether it's in gear or neutral between 60-70 km/h. There's a ticking sound before or after. I had it disassembled once at 30,000 km, they said there was nothing, so we closed it. We disassembled it again at 95,000. This time, the pressure pad, fork axle seals, etc. were changed. Also, the 3rd-4th gear synchronizer caused a problem. I replaced it. I spent 22,000 TL. Almost all the bearings were changed. That sound still persists. It's like a joke. I've stopped using it like that. I've accepted it. My car is now 102,000. It's been 1000 km and I'm not having much of a problem. You're going to install a used transmission, if you're lucky and it turns out well, there's no room for that. Some of these vehicles really have transmission problems, some never experience them, but I experienced them and I still experience them. I've changed the timing set twice, and now the ESP light is on, and you'll lose your mind for no reason.
